2012 Acura TL Technical Service Bulletins
2012 Acura TL Technical Service Bulletins:
TSB 11-005 - 2012 TL: TQI Information Applies To: 2012 TL - All http://www.urvi.net/forumfiles/SB/B11-005.PDF http://techinfo.honda.com/rjanisis/pubs/SB/B11-005.PDF TSB 08-041 - 2009-13 TL: TQI of the Navigation System Applies To: 2009-13 TL With Navigation - All http://www.urvi.net/forumfiles/SB/B08-041.PDF http://techinfo.honda.com/rjanisis/pubs/SB/B08-041.PDF TSB 09-059 - Front Door Panel Fabric Pulls Out Along the Edge Applies To: 2009-12 TL - All http://www.urvi.net/forumfiles/SB/B09-059.PDF http://techinfo.honda.com/rjanisis/pubs/SB/B09-059.PDF TSB 10-008 - Retractable Master Key Does Not Lock in Its Extended Position Applies To: 2009-12 TL (without push button start) http://www.urvi.net/forumfiles/SB/B10-008.PDF http://techinfo.honda.com/rjanisis/pubs/SB/B10-008.PDF TSB 11-004 - Clutch Pedal Pops, Squeaks, or Clicks Applies To: 2010-11 TL - All with M/T 2012 TL with M/T - From VIN 19UUA9E..CA000001 thru 19UUA9E..CA000672 http://www.urvi.net/forumfiles/SB/B11-004.PDF http://techinfo.honda.com/rjanisis/pubs/SB/B11-004.PDF TSB 11-012 - TIGHTEN FUEL CAP Message Is On Without DTC P0455 or P0456 Applies To: 2012 TL 2WD – From VIN 19UUA8...CA000001 thru 19UUA8...CA005403 2012 TL SH-AWD A/T – From VIN 19UUA9F..CA000001 thru 19UUA9F..CA011151 2012 TL SH-AWD M/T – From VIN 19UUA9E..CA000001 thru 19UUA9E..CA011466 http://www.urvi.net/forumfiles/SB/B11-012.PDF http://techinfo.honda.com/rjanisis/p...nu/B11-012.PDF TSB 11-016 - HFL Phonebook Imports Each Time, Call History Refreshes Each Time, Voice Tag Doesn’t Work, and AcuraLink Voice Unclear Applies To: 2012 TL with Navi - From VIN 19UUA8...CA000001 thru 19UUA8...CA009401 and From VIN 19UUA9...CA000001 thru 19UUA9...CA002936 http://www.urvi.net/forumfiles/SB/B11-016.PDF http://techinfo.honda.com/rjanisis/pubs/SB/B11-016.PDF TSB 11-024 - Rear Shelf Area Clicks, Taps, or Ticks Applies To: 2009-12 TL - All http://www.urvi.net/forumfiles/SB/B11-024.PDF http://techinfo.honda.com/rjanisis/pubs/SB/B11-024.PDF TSB 11-025 - Right Rear Wheelwell Area Clicks, Taps, or Ticks Applies To: 2009-12 TL - All http://www.urvi.net/forumfiles/SB/B11-025.PDF http://techinfo.honda.com/rjanisis/pubs/SB/B11-025.PDF TSB 11-027 - Upper B-Pillar or Moonroof Area Clicks, Rattles, or Taps Applies To: 2009–11 TL – All 2012 TL 2WD – From 19UUA8...CA000001 thru 19UUA8...CA030468 2012 TL SH-AWD – From 19UUA9...CA000001 thru 19UUA9...CA009652 http://www.urvi.net/forumfiles/SB/B11-027.PDF http://techinfo.honda.com/rjanisis/pubs/SB/B11-027.PDF TSB 12-013 - MID Shows BATTERY CHARGE LOW Applies To: 2012 TL 2WD - From VIN 19UUA8...CA000001 thru 19UUA8...CA008239 2012 TL SH-AWD - From VIN 19UUA9...CA000001 thru 19UUA9...CA002516 http://www.urvi.net/forumfiles/SB/B12-013.PDF http://techinfo.honda.com/rjanisis/pubs/SB/B12-013.PDF TSB 12-041 - Front Suspension Clunk in Hot Weather Applies To: 2009-13 TL - All http://www.urvi.net/forumfiles/SB/B12-041.PDF http://techinfo.honda.com/rjanisis/pubs/SB/B12-041.PDF TSB 13-007 - Rattle or Vibration From the Rear Speakers Applies To: 2009-12 TL - All http://www.urvi.net/forumfiles/SB/B13-007.PDF http://techinfo.honda.com/rjanisis/pubs/SB/B13-007.PDF TSB 14-006 - MIL Comes On With DTC P0455 and/or P0456 Applies To: 2012 TL - All - All 2013 TL - 2WD - From VIN 19UUA8...DA000001 - 19UUA8...DA000686 2013 TL - SH-AWD - From VIN 19UUA9...DA000001 - 19UUA9...DA000191 http://www.urvi.net/forumfiles/SB/B14-006.PDF http://techinfo.honda.com/rjanisis/p...nu/B14-006.PDF TSB 14-027 - Moonroof Will Not Auto-Close or Reverses Direction Applies To: 2009-14 TL - ALL - ALL http://www.urvi.net/forumfiles/SB/B14-027.PDF http://techinfo.honda.com/rjanisis/p...nu/B14-027.PDF TSB 14-048 - New Warranty Instructions for TPMS-Related Repairs Applies To: 2006-14 TL - ALL - ALL http://www.urvi.net/forumfiles/SB/B14-048.PDF http://techinfo.honda.com/rjanisis/p...nu/B14-048.PDF TSB 14-049 - Gurgle or Chirp from Under Hood at Cold Start-Up Applies To: 2012-14 TL - ALL with A/T - ALL http://www.urvi.net/forumfiles/SB/B14-049.PDF http://techinfo.honda.com/rjanisis/p...nu/B14-049.PDF TSB 15-013 - Driver’s Seat Cushion Cover Comes Loose Applies To: 2012-14 TL - Advance, Advance with SH-AWD - ALL http://www.urvi.net/forumfiles/SB/B15-013.PDF http://techinfo.honda.com/rjanisis/p...nu/B15-013.PDF TSB 16-010 - Safety Recall: Takata Driver’s Airbag Inflator Applies To: 2009-14 TL - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B16-010.PDF http://techinfo.honda.com/rjanisis/p...nu/B16-010.PDF TSB 16-030 - Product Update: 2012 TL Software Update for Lock-up Clutch Function Applies To: 2012 TL - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B16-030.PDF http://techinfo.honda.com/rjanisis/p...nu/B16-030.PDF TSB 16-040 - Warranty Extension: 2012 TL Torque Converter Applies To: 2012 TL - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B16-040.PDF http://techinfo.honda.com/rjanisis/p...nu/B16-040.PDF TSB 16-046 - Judder from the Torque Converter Lock-Up Clutch This bulletin is replaced by 18-047, 2012-14 TL: Judder from the Torque Converter Lock-Up Clutch (Snapshot Upload Required) http://www.urvi.net/forumfiles/SB/B16-046.PDF http://techinfo.honda.com/rjanisis/p...nu/B16-046.PDF TSB 18-009 - Engine Oil Consumption Exceeds Client Expectations The bulletin is replaced by S/B 19-006, Warranty Extension: Engine Oil Consumption Exceeds Client Expectations http://www.urvi.net/forumfiles/SB/B18-009.PDF http://techinfo.honda.com/rjanisis/p...nu/B18-009.PDF TSB 18-020 - Warranty Extension: Customer Support Program For Driver's Airbag Inflator for 2013-14 ILX Hybrid and Other Listed Years and Models (Expires February 28, 2026) Applies To: 2009-14 TL - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B18-020.PDF http://techinfo.honda.com/rjanisis/p...nu/B18-020.PDF TSB 18-047 - 2012-14 TL: Judder from the Torque Converter Lock-Up Clutch (Snapshot Upload Required) Applies To: 2012 TL - 2WD - From VIN 19UUA8F...CA035307 thru 19UUA8F...CA040693 2012 TL - 4WD - From VIN 19UUA9F...CA011186 thru 19UUA9F...CA012783 2013-14 TL - ALL - ALL http://www.urvi.net/forumfiles/SB/B18-047.PDF http://techinfo.honda.com/rjanisis/p...nu/B18-047.PDF TSB 18-048 - 2012-14 TL: Judder from the Torque Converter Lock-Up Clutch After Software Update (Snapshot Upload Required) Applies To: 2012 TL - 2WD - From VIN 19UUA8F...CA035307 thru 19UUA8F...CA040693 2012 TL - 4WD - From VIN 19UUA9F...CA011186 thru 19UUA9F...CA012783 2013-14 TL - ALL - ALL http://www.urvi.net/forumfiles/SB/B18-048.PDF http://techinfo.honda.com/rjanisis/p...nu/B18-048.PDF TSB 19-006 - Warranty Extension: Engine Oil Consumption Exceeds Client Expectations Applies To: 2009-14 TL - SH-AWD - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B19-006.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-006.PDF TSB 19-018 - Safety Recall: Driver's Airbag Replacement Inflator Can Be Over-Pressurized Applies To: 2009-14 TL - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B19-018.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-018.PDF TSB 19-021 - Warranty Extension: Steering Feels Heavy, EPS Indicator Blinks with No DTCs or Comes On Steady with DTC 32-09, 32-08, or 61-04 Applies To: 2012-14 TL - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B19-021.PDF http://techinfo.honda.com/Rjanisis/p...nu/B19-021.PDF TSB 19-043 - Safety Recall: Takata Driver's Airbag Inflator Applies To: 2009-14 TL - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B19-043.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-043.PDF TSB 19-052 - Warranty Extension: Engine Oil Consumption Exceeds Client Expectations Applies To: 2009-14 TL - SH-AWD - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B19-052.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-052.PDF TSB 19-059 - Service Manual Update: Evaporative Emission (EVAP) Control Diagram Applies To: 1999-14 TL http://www.urvi.net/forumfiles/SB/B19-059.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-059.PDF TSB 20-006 - Warranty Extension: Customer Support Program for Driver's Airbag Inflator for 2013 ILX and Other Listed Years and Models (Expires January 31, 2030) Applies To: 2009-14 TL - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B20-006.PDF http://techinfo.honda.com/rjanisis/p...nu/B20-006.PDF |
Originally Posted by EE4Life
(Post 16306674)
TSB 16-046 - Judder from the Torque Converter Lock-Up Clutch was revised. This bulletin is replaced by 18-047, 2012-14 TL: Judder from the Torque Converter Lock-Up Clutch (Snapshot Upload Required)
Added new TSBs: TSB 18-047 - 2012-14 TL: Judder from the Torque Converter Lock-Up Clutch (Snapshot Upload Required). TSB 18-048 - 2012-14 TL: Judder from the Torque Converter Lock-Up Clutch After Software Update (Snapshot Upload Required). |
Not sure. Never had the problem. Or if I did, I've never noticed it.
What I'd like to know is how you're supposed to upload a snapshot of a torque converter judder :confused: |
(Post 16366774)
Added new TSB 19-006 - Warranty Extension: Engine Oil Consumption Exceeds Client Expectations.
Originally Posted by mrphilipanderson
(Post 16360558)
What are the symptoms of TSB 18-047
(Post 16366774)
(Post 16394434)
Added new TSB 19-018 - Safety Recall: Driver's Airbag Replacement Inflator Can Be Over-Pressurized.
Added new TSB 19-052 - Warranty Extension: Engine Oil Consumption Exceeds Client Expectations.
Added new TSB 19-059 - Service Manual Update: Evaporative Emission (EVAP) Control Diagram.
Added new TSB 20-006 - Warranty Extension: Customer Support Program for Driver's Airbag Inflator for 2013 ILX and Other Listed Years and Models (Expires January 31, 2030).
My power steering just failed when my wife was driving my 12TL. Nice to see extended warranty on EPS module. Going to call dealer and hope my VIN is covered.
