2012 Acura TL Rear Tail Light Brake Bulb Part # ???
Can't seem to find which part # to replace the rear tail brake light bulb? Any help is appreciated! Thank you!
Brake lights are LED.... turn signal and other lamps are bulbs.
If your tail-brake light is out it's gonna be expensive to replace. The LED light is embedded into the tail light assembly.
Items 5 & 6: https://www.acurapartsforless.com/v-...-license-light OEM is about $375 for each side I would spend some time to diagnose the problem to verify if indeed the LED light is malfunctioning. Amazon has aftermarket assemblies (a pair) for about $370 RockAuto has aftermarket assemblies for about $147 each. https://www.rockauto.com/en/catalog/...p+assembly,807 I've installed TYC headlight assemblies on my son's 2004 Accord and they fit very well. But those assemblies utilized standard bulbs and not LED. I also utilized a TYC radiator/AC full fan assembly (including electric motors) on his car and they have been working fine for about 10 months (~9,000 miles) |
