2012 Acura TL 3.5 Cold start noise
1 Attachment(s)
My 2012 Acura TL has 120,000 miles on it. I notice the first start of the day or cold start after a few seconds it makes a rattle noise. I have already done these maintenance a couple of months ago a trans flush , new serpentine belt, new battery and spark plugs. I attached a video the noise is at 10 seconds in. Please let me know if anyone knows what part could be causing this noise. Thanks
Can anyone provide some help or suggestions Thanks
Can't really hear a noise in the video but after a cold start does it sound somewhat like a bubbling rattling noise coming from the left front of the vehicle? If so when was the last time the transmission filter was changed?
2 months ago it had a trans flush , new serpentine belt, new battery and spark plugs according to the service records. I just recently bought it. The noise is at the 10 second mark it is a little hard to hear but its there.
A trans flush and a transmission filter replacement are two different things. You need to have the transmission filter changed. You can order it off of amazon for around $25 and it isn't too difficult to change as long as you are handy. The filter is actually directly below the battery tray. Do a search here for transmission filter change and you should find a bunch of information.
I didn't realize that i called the dealer and they said they don't normally change the filter with the trans oil change. I was surprised that's not automatically done. I will change it and see if it fixes the issue. Thanks
I just changed mine a couple weeks ago, if you run into any issues like the fact that the battery tray has a hidden bolt underneath it let me know, I’ll give any tips or advice I can
See TSB 14-049 - Gurgle or Chirp from Under Hood at Cold Start-Up in the 2012 TSB thread.
https://acurazine.com/forums/fourth-...letins-945428/ |
Thanks everyone, I will update the status once i change the filter to let you know if it worked.
Great info, I get the same gurgle sound briefly on cold starts.
I had the filter changed and the mechanic discovered the front axel seal had a leak so both were changed. Just got the car back yesterday and seems to be running great.
How much did the front axle seal change cost you?
Dealer wanted $450 and the local shop did it for $130.
