2011 Acura TL Technical Service Bulletins
2011 Acura TL Technical Service Bulletins:
TSB 10-029 - 2011 TL: TQI and New Model Service Information Applies To: 2011 TL - All http://www.urvi.net/forumfiles/SB/B10-029.PDF http://techinfo.honda.com/rjanisis/pubs/SB/B10-029.PDF TSB 08-041 - 2009-13 TL: TQI of the Navigation System Applies To: 2009-13 TL With Navigation - All http://www.urvi.net/forumfiles/SB/B08-041.PDF http://techinfo.honda.com/rjanisis/pubs/SB/B08-041.PDF TSB 09-012 - MID or Navi Shows a Check Engine Oil Level Message, Low Oil Pressure Indicator May Be On Applies To: 2009-11 TL - All http://www.urvi.net/forumfiles/SB/B09-012.PDF http://techinfo.honda.com/rjanisis/pubs/SB/B09-012.PDF TSB 09-059 - Front Door Panel Fabric Pulls Out Along the Edge Applies To: 2009-12 TL - All http://www.urvi.net/forumfiles/SB/B09-059.PDF http://techinfo.honda.com/rjanisis/pubs/SB/B09-059.PDF TSB 10-008 - Retractable Master Key Does Not Lock in Its Extended Position Applies To: 2009-12 TL (without push button start) http://www.urvi.net/forumfiles/SB/B10-008.PDF http://techinfo.honda.com/rjanisis/pubs/SB/B10-008.PDF TSB 11-004 - Clutch Pedal Pops, Squeaks, or Clicks Applies To: 2010-11 TL - All with M/T 2012 TL with M/T - From VIN 19UUA9E..CA000001 thru 19UUA9E..CA000672 http://www.urvi.net/forumfiles/SB/B11-004.PDF http://techinfo.honda.com/rjanisis/pubs/SB/B11-004.PDF TSB 11-024 - Rear Shelf Area Clicks, Taps, or Ticks Applies To: 2009-12 TL - All http://www.urvi.net/forumfiles/SB/B11-024.PDF http://techinfo.honda.com/rjanisis/pubs/SB/B11-024.PDF TSB 11-025 - Right Rear Wheelwell Area Clicks, Taps, or Ticks Applies To: 2009-12 TL - All http://www.urvi.net/forumfiles/SB/B11-025.PDF http://techinfo.honda.com/rjanisis/pubs/SB/B11-025.PDF TSB 11-027 - Upper B-Pillar or Moonroof Area Clicks, Rattles, or Taps Applies To: 2009–11 TL – All 2012 TL 2WD – From 19UUA8...CA000001 thru 19UUA8...CA030468 2012 TL SH-AWD – From 19UUA9...CA000001 thru 19UUA9...CA009652 http://www.urvi.net/forumfiles/SB/B11-027.PDF http://techinfo.honda.com/rjanisis/pubs/SB/B11-027.PDF TSB 12-029 - Warranty Extension: Torque Converter, Product Update: PCM Update for Lock-Up Clutch Function Applies To: 2009-11 TL with SH-AWD - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B12-029.PDF http://techinfo.honda.com/rjanisis/pubs/SB/B12-029.PDF TSB 12-041 - Front Suspension Clunk in Hot Weather Applies To: 2009-13 TL - All http://www.urvi.net/forumfiles/SB/B12-041.PDF http://techinfo.honda.com/rjanisis/pubs/SB/B12-041.PDF TSB 13-007 - Rattle or Vibration From the Rear Speakers Applies To: 2009-12 TL - All http://www.urvi.net/forumfiles/SB/B13-007.PDF http://techinfo.honda.com/rjanisis/pubs/SB/B13-007.PDF TSB 14-027 - Moonroof Will Not Auto-Close or Reverses Direction Applies To: 2009-14 TL - ALL - ALL http://www.urvi.net/forumfiles/SB/B14-027.PDF http://techinfo.honda.com/rjanisis/p...nu/B14-027.PDF TSB 14-048 - New Warranty Instructions for TPMS-Related Repairs Applies To: 2006-14 TL - ALL - ALL http://www.urvi.net/forumfiles/SB/B14-048.PDF http://techinfo.honda.com/rjanisis/p...nu/B14-048.PDF TSB 16-010 - Safety Recall: Takata Driver’s Airbag Inflator Applies To: 2009-14 TL - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B16-010.PDF http://techinfo.honda.com/rjanisis/p...nu/B16-010.PDF TSB 16-033 - Warranty Extension: Software Update for Lock-up Clutch Function Based on Client Complaint Applies To: 2009-11 TL - ALL 2WD - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B16-033.PDF http://techinfo.honda.com/rjanisis/p...nu/B16-033.PDF TSB 16-036 - Warranty Extension: 2009–11 TL Torque Converter Applies To: 2009-11 TL - ALL 2WD - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B16-036.PDF http://techinfo.honda.com/rjanisis/p...nu/B16-036.PDF TSB 18-009 - Engine Oil Consumption Exceeds Client Expectations The bulletin is replaced by S/B 19-006, Warranty Extension: Engine Oil Consumption Exceeds Client Expectations http://www.urvi.net/forumfiles/SB/B18-009.PDF http://techinfo.honda.com/rjanisis/p...nu/B18-009.PDF TSB 18-020 - Warranty Extension: Customer Support Program For Driver's Airbag Inflator for 2013-14 ILX Hybrid and Other Listed Years and Models (Expires February 28, 2026) Applies To: 2009-14 TL - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B18-020.PDF http://techinfo.honda.com/rjanisis/p...nu/B18-020.PDF TSB 19-006 - Warranty Extension: Engine Oil Consumption Exceeds Client Expectations Applies To: 2009-14 TL - SH-AWD - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B19-006.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-006.PDF TSB 19-018 - Safety Recall: Driver's Airbag Replacement Inflator Can Be Over-Pressurized Applies To: 2009-14 TL - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B19-018.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-018.PDF TSB 19-043 - Safety Recall: Takata Driver's Airbag Inflator Applies To: 2009-14 TL - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B19-043.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-043.PDF TSB 19-052 - Warranty Extension: Engine Oil Consumption Exceeds Client Expectations Applies To: 2009-14 TL - SH-AWD - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B19-052.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-052.PDF TSB 19-059 - Service Manual Update: Evaporative Emission (EVAP) Control Diagram Applies To: 1999-14 TL http://www.urvi.net/forumfiles/SB/B19-059.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-059.PDF TSB 20-006 - Warranty Extension: Customer Support Program for Driver's Airbag Inflator for 2013 ILX and Other Listed Years and Models (Expires January 31, 2030) Applies To: 2009-14 TL - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B20-006.PDF http://techinfo.honda.com/rjanisis/p...nu/B20-006.PDF |
I have this exact problem, but am out of warranty. Is their any recourse for this or is this completely an out-of-pocket expense to get this fixed? |
Added new TSB 19-052 - Warranty Extension: Engine Oil Consumption Exceeds Client Expectations.
Added new TSB 19-059 - Service Manual Update: Evaporative Emission (EVAP) Control Diagram.
Added new TSB 20-006 - Warranty Extension: Customer Support Program for Driver's Airbag Inflator for 2013 ILX and Other Listed Years and Models (Expires January 31, 2030).
