2010 TL alarm randomly goes off
I've been going through this site looking for some clues. I did suspect it was the hood latch sensor. Based on my reading, looks like it is. And the alarm goes off everytime it rains or extremely humid. WhenI lock the doors, I don't hear the beep and the red blinking light does not go on in the dash. I would have to open the hood then close it. After only doing so would I hear the beep when i lock the doors and the red light comes on. My neighbors don't like me very much at this time. I plan to just go ahead and disconnect the sensor. Posting here to find out if there is anything special i need to do. I know I may need to remove the panel convering the radiator to get to the connector. Is the panel difficult to remove? Anything more...please advise. Thanks!
The same thing happened to me a year or so ago, but i was able to bend the metal lead on the hood latch micro-switch back to a point where the alarm stopped randomly going off (try looking into that, its a quick, cheap fix and there should be some tutorials on youtube). If you just unplug the hood latch sensor i believe you will never be able to arm the system and get the "beep" when locking the car, just an FYI.
i guess i'll have to access the latch by removing the grill first. just thinking about it is making me nervous! I read the other post about how to remove the grill. Them plastic pins always make me nervous...i tend to break them.
It is possible to remove the latch by just taking off the 2-3 bolts holding the actual latch assembly on. It may be a bit of a tight fit but i was able to take it off by leaving the grill on and only pulling the engine covers off. The only thing to make a note of is where the little index lines line up so when you reinstall the hood height is correct when it is closed.
daoism76
07-16-2012 12:30 AM
