2009 Cabin Filter
2009 Cabin Filter
How do you replace a 2009 TL cabin filter? Is there a DIY video or pictures for the 4G? I have seen videos on you tube for the 3G, but the glove box for the 4G is different.
Easiest thing in the entire car.
- Open Glove box
- remove all your crap
- pull out the shelf/divider
- squeeze the tabs on the now exposed cabin filter
- pull out cabin filter
- replace filter element
- reinsert, you get the rest...
All of 2 minutes to do. Fram makes a baking soad embedded filter supposedly to freshen the air, I actually can't tell if it is working to "freshen" the air. I would love a charcoal based hepa style filter. The good news is this cabin filter is fairly standard across the Honda line I know the Accord and CR-V use the same filter.
- Open Glove box
The following 7 users liked this post by jrkkm:
Acc-Rite (08-29-2012),
brana (08-28-2012),
DopeAcura (08-29-2012),
Franco2112 (06-17-2013),
RachilPlusOne (03-08-2013),
and 2 others liked this post.
Dealer sent me a coupon flyer and they want $80 to change it.
Now granted the filter costs $30 but still. It should take you no more than 30 minutes and that includes going through all the crap in your glove box that you've accumulated over time.
I've tried that. I'm trying to get he pics from my pictures but it's not working. Do have to send them somewhere first like photo bucket so I can have a URL. Thanks
Yes, you have to host them on imageshack or photobucket or any image hosting site then paste that url for it to work, I believe
Is anyone else making their own filters? I make my own using 3M Filtrete 1500 home furnace filters. Haven't tried it in this car yet, but I'm sure it will be the same as the other 2 cars. It works great and comes out to $2 or $3 per filter. It's probably a better filter too!
Sorry, I by accidentally pressed submit, my post got cut off.
I just recentlt started to do what you've been doing, I've been hearing it around a lot and though maybe I'll try it so, I purchased my own furnace filter from home depot cut them around and made my own cabin filters, it really does work great. I have not done it by using a 3M Filtrete though, I'm willing to give this a shot. Is there a particular reason of why you decided to use a 3M filtrete, does it help in anyway or improve anything?
Also try this!
Is anyone else making their own filters? I make my own using M Filtrate 1500 home furnace filters. Haven't tried it in this car yet, but I'm sure it will be the same as the other 2 cars. It works great and comes out to $2 or $3 per filter. It's probably a better filter too!
I don't think it will be dirty at all, probably it will be like new, why?? We live in California, San Diego home of Jerry Brown.. I mean with this combination how could we have anything but clean air!
Thanks for the instructions and pix. I just bought a 2009 WDP Tl and was wondering about the cabin filter. So great to have a place where my questions are answered before I even ask them!
Blown With Air!
Anyone know if there is an activated charcoal filter available?
Recently, I was able to reach in and squeeze both tabs without any tools. If you can't reach it with your finger, try gently using a small flat blade screwdriver to press the tab.
Also I noticed that when I replaced the filter, it is important that the forward and rear pleats properly go into the frame. If you look at the plastic frame, there are some tabs to hold the outer pleats. My guess is that if the pleats don't catch in those tabs, air could flow around the filter. Did anyone else notice this?
This looks so much easier than it was in my 1st Gen TL. Getting the glove box door off was a pain!
emanon256 (08-15-2011)
Thanks also! I just bought a TL and noticed a musty smell sometimes when the car would first turn on. Thanks to this thread I checked my filter and there was even a couple very small leaves in it.... lol
Ordered one from Amazon.
For any Canadian members, the Fram filters are in the current PartSource flyer...looks like their about $5 cheaper than at Canadian Tire (PartSource's parent). Not sure if I need to replace mine yet, but I'll likely pick on up anyway.
Great post with easy instructions. I would add that you must really pull on the shelf to get it out. Thought I might break it but it did finally pop out. Took longer to empty and put back the stuff in the glove box than it took to change the filter. I had to pull very hard on the shelf, others might be less tight.
