2009 Acura TL Key FOB Battery Change?
Keyfob battery replacement
On the keyless fob, the battery is easy to replace. Just remove the built-in key and then pry open the case using a coin in the slot next to where the key inserted into the case. The coin battery is a CR2032. Snap case back together once you replace the battery. I just did my 2009 TL fob about two weeks ago.
mel88hrman (07-27-2012)
NO!! ... lol
I changed mine since i didnt know how long it was in use and i didnt want to take any chances of it crapping out on me. I bought a six pack of batteries from ebay for $3 so i'm covered for a good while.
The car will give you a warning message if the fob battery is low on juice.
Odd. Mine gave me a message a couple of weeks ago. Drove it that day and replaced the battery the next day.
If your fob battery does die you can always insert it in the ignition slot and still be able to start your car, it's good to know just in case.
Base Model TLs take a CR1616 and the OEM part number is - 72148-S0A-000 : $6.94 each
Tech Model and above TLs take a CR2032 and that part number is - 72148-SNB-000 : $10.46 each
-greg
JTL12 (02-24-2015)
mada51589
05-03-2022 08:54 PM
tman570
06-11-2019 07:56 AM
nanos
11-12-2015 08:41 PM
asahrts
09-04-2015 05:55 PM
