2009 Acura TL FWD or SH-AWD
Hello - I live in north jersey and need to buy a 2009 Acura TL for my wife.
I need your expertise and guidance.
Should i go for a FWD with Tech Package or an SH-AWD without Tech package.
Will the FWD be ok and safe in the north jersey winter snow??? We have a new born and are looking for a safe and reliable car.
- AWD rides stiffer than FWD, but still a very compliant ride
- AWD steering wheel is fatter
- AWD steering has better feedback, FWD to me feels numb and ove rboosted
- AWD will suck more gas, probably 2+ MPG difference
- AWD has sportier seats with more side bolstering and over color stitching
- AWD has 18 inch wheels (unless you get the 19 inch HPT) vs. 17 for FWD
I used to live in NY/NJ and found FWD was always good in the bad weather, BUT I had never driven AWD before and can tell you if you look at the folks on this forum that drive the AWD in bad weather they will tell you it is like driving in normal weather. For safety I would opt for AWD over FWD, but you/your wife are only part of the accident equation, it is all the other idiots on the road that will kill you
Also how important is the TECH, the NAVI and awesome, the ELS is far superior to the base sound system?
And don;t get me wrong I love my AWD, but have you looked at a G37x, their AWD is not as sophisticated, but I think you can at least compare the 2, they shdoul be priced similar.
The TL brake system features a firm pedal feel that enables the precise deceleration and modulation demanded of high-performance driving.
12.6-inch ventilated discs in the front and 13.2-inch solid discs in the rear comply readily upon demand.
The system comes with the Anti-lock Braking System (ABS), Electronic Brake Distribution (EBD) and Brake Assist.
TL SH-AWD models have additional brake cooling from ducts in the front air dam.
You need to read through these forums, to really understand the differecnes. Also she shoudl drive both, they ride different. I'll take a quick stab of the differences IMO:
I thought the brakes were the same? Or at least the rotors are? Right from acura.com:
I think that the TL SH-AWD braking performance is better due to the optional high-performance summer tires that comes with the test vehicles that are sent to the magazines. The cooling ducts are only there to prevent brake fade because these ducts cool the brakes after repetitive stops...they don't actually shorten the braking distance, they just prevent it from getting longer after repeated stops.
In other words, given the same tires, TL and TL SH-AWD will probably have the same braking distance after the first stop. In fact, since the SH-AWD model is heavier, the initial stop may be longer than the regular TL.
Acura3204, if your debate over SH-AWD vs Tech packages are strictly financial ones, then you should know that prices have been significantly reduced in this economy. I have heard through this forum of folks buying 09 TL SH-AWD w/Tech for several thousand less than the $2K and change MSRP.
On another point, I live in Connecticut and will tell you that FWD will suffice for 90% of the bad weather your wife will encounter but that AWD system is great in the snow. The driveway entrance to my condo complex is a steep hill that has an s-curve half-way up at it's highest incline angle. During two snowstorms this year, my next door neighbor had to park his FWD lexus at the bottom of the hill. I had zro problems driving up in either of the AWD vehicles I've owned while living there and the TL's AWD is the better of them.
If, after reading all of this you are still uncertain which to get, I would advise you to err on the side of caution and get the SH-AWD. Safety before toys. Best of luck.
From acura.com
245/50 R17 98V Bridgestone Turanza All-Season | TL
245/45 R18 96V Michelin Pilot HX MXM4 All-Season | TL SH-AWD
245/40 ZR19 94Y Michelin Pilot Sport S2 Summer | TL SH-AWD WITH HPT
You didn't say if your wife works outside the home and must get to work regardless of the weather. as was previously mentioned, FWD will be adequate for 90% of the weather, but nothing beats AWD if you MUST get to work and the conditions are bad. AWD is also excellent in heavy rain and standing water. And of course snow tires are a great investment. Despite an initial investment which is substantial, you will recover much of it in the longer timeframe of tire replacement.
Here's more on AWD's brake upgrades...
source: http://www.hondanews.com/categories/735/releases/4677
SH-AWD® Brake Upgrades
In keeping with its mission as a premium performance sport sedan, the 2009 Acura TL SH-AWD® features special front fascia-mounted cooling ducts for the front brakes and proprietary vacuum booster specifications. The system upgrades allow even more confident and consistent braking in repeated high-use conditions such as during spirited mountain driving. Hill Start Assist (HSA) is also added to eliminate vehicle rollback when starting on a sloped surface.
The SH-AWD® Advantage
Along with the larger engine, the TL SH-AWD® also gets suspension, brake and steering upgrades that further sharpen its performance. The SH-AWD® system is ideally positioned to lead the performance luxury sedan category where the TL competes, as 35-percent of all vehicles in the class have all-wheel drive. Priced competitively with AWD packages on competing vehicles, the TL SH-AWD® is expected to be a strong competitor in the segment.
While the TL offers satisfyingly quick turn-on, flat cornering, a high level of grip and highly neutral characteristics when driven aggressively, with its larger and more powerful engine, and more sporting suspension tuning and tires, the SH-AWD® model takes performance a step further to deliver racetrack-quality handling-without losing the composure required of a daily driver.
AZ Community Team
Received 7,770 Likes
If weather is going to be an issue, then there is really no choice but to go with the
AWD. Im going to be honest and say the FWDs steering is crap. On the freeway,
the car swerves into other lanes if you phase out for a second. With my 2005 TL, I can pretty much fall asleep and the car would be going straight. With the new FWD TL, you have to be 100% alert, especially if you drive in harsh weather.
Also, there is no reason to get this car if you dont get the tech package. If I didnt care about tech, I would go with a BMW 528xi without extra options. They have a $2500 incentive and extremely low apr.
I would just use the EPA highway mileage x fuel tank size. That is your best way to compare between vehicles. I have found that the new EPA rating is fairly accurate for the average (non-lead foot) driver...in fact, for me, the EPA rating has been dead accurate in the vehicles i have, but then again, i am an average driver.
As a less than 24 hour owner of a AWD TL, I can tell you it kicks butt. Coming from a 99TL, performance and handling of the 09 is far superior. It has a lot of zip, handles extremely well, seems solid as a rock.
Unless you can't spend the extra $3K on AWD, I can't recommend it enough. This will be a FUN car to drive for the next 10 years.
One advantage I find witht he 4G at least phycologically is I go 30-50 miles more per tank than my Type-S, and not becasue of the MPG, becasue they seem to have dialed in the low feul light much better, in my 3G it woudl almost always come on when I had 3.5+ gallons in the tank, on my 4G I am filling up with 3 or less gallanons left and the warning light has not come on, the one time it did I had about 2-2.5 gallons left in the tank. So on my Type-S even though I got 2MPG better I was filling up around 300-305 miles per tank, on my 4G I am going 325-340 miles per tank so while I'm using more gas at least I'm filling up less often.
AZ Community Team
Qu
spoiler900
5G TLX Photograph Gallery
09-11-2015 09:39 PM
