Wiring Schematic to run fogs w/o headlamps?
I've seen a few tsx's around here with their fogs on separate from the headlamps. I'm guessing its some kind of bypass or separate switch other then the OEM switch on the left lever.
anyone have a wiring diagram or a write up on what needs to be done? I want to run them separate with just my parking lamps
Its all about powering the fog relay coil by other power sources of your choice instead of what it is powered by stock.
I think 04-05 is slightly different than 06-08.
With the way you want, you'll use the parklight positive wire to power the positive side of the coil, and the coil's ground will connect to a wire in the steering column that triggers with the OEM fog switch (blue/white). That's how I've seen it done.
This thread might help out:
https://acurazine.com/forums/showthr...=675628&page=3
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
