Will a TL-S or 2009 TSX steering wheel fit 06-08 TSX?
Old 01-04-2009, 05:44 PM
大阪
ScOeDeLiC's Avatar
I noticed that they both have similar functions and buttons.. was wondering if we can use the TL Type S and/or 2009 TSX steering wheel on our 2006-2008 TSX. Has anyone tried it before? Would it be a direct swap? Would it even work?
Thanks!!!
PS
I was also wondering if the new TSX steering wheel would work as well??
Old 01-04-2009, 09:57 PM
fast1's Avatar
I am not a fan of the radio buttons on the '09 TSX. They feel quite a bit cheaper and are much smaller than what you have currently. I'm vote for the TL steering wheel but can't help ya out as far as compatibility. I would venture a yes but you never know.
Old 01-05-2009, 01:05 AM
大阪
ScOeDeLiC's Avatar
hope to find an answer... would really like to see if it does work
Old 01-05-2009, 09:04 AM
Make a hole, coming thru!
davidspalding's Avatar
IIRC someone asked about compatibility of other Acura wheels before ... did you try searching?
Old 04-06-2009, 09:22 AM
Esquee's Avatar
Would you happen to know if it is possible to fit an 08 tl wheel onto an 05??? I like the design for the 08 better..
Old 04-06-2009, 09:50 AM
Registered TSXer
frank1123's Avatar
that TL-S steering wheel looks nice but our cars don't come type S so it'd be lame unless you can take the type s badge off
Old 04-06-2009, 11:10 AM
Nevermind how it looks ... is the wiring even compatible.... You'd probably have to review service manual wiring diagrams, particularly the pin-out.
By "'05," Esquee, I presume you mean a 2005 TSX. If you mean TL, then go directly to tl.acurazine.com, do not pass GO, do not collect $200.
The functions are probably the same ... switches that close a circuit momentarily (a guess).
Old 04-06-2009, 09:31 PM
アコードタイプSとくれば、喜びもひとし お。思わず投
lito's Avatar
I like the new TSX steering wheel If we can swap EP3 or S2K steering wheels on the 1st Gen TSX I don't see why not. If you know someone who has a 2nd Gen TSX you should try swapping steering wheels, it's fairly simple.
Old 04-07-2009, 07:29 AM
Oliver!!!
litesout's Avatar
The actual wheel swap probably isn't the issue, its the buttons on the wheel. Compatibility is the issue. The TL wheel has an extra button on it for the MID that the TSX doesn't have. The TL MID setup is different and makes use of a third button. That would make me think it might now work. I can't vouch for it, but I'm guessing the 09 TSX MID works the same as the TL and makes use of the third button.
As far as actual button function, I read somewhere in here that the radio buttons work on a 2 wire system. There's a hot and return and the different buttons add varying levels of resistance to the circuit. The fewer wires you have running through the rotating wheel, the better being the philosophy behind that.
If somebody has the electrical manuals for the year of TSX in question and the TL or 2G TSX electrical manuals I'm sure you could figure it out.
And IIRC the S2K wheel and EP3 wheels don't have the function buttons on them that the stock TSX wheel does. You lose MID and radio buttons. I read a thread on the TL side about swapping out the S2k and RSX wheels for 2G TL wheels. Other than the airbags (single stage in the older models vs dual stage in the newer ones) its a direct swap. You just lost the audio controls. None of the cars in question have the MID though.
Old 07-12-2009, 09:10 AM
2011 ZCP E92 M3!!
dave_ramkumar's Avatar
can the 08 type s wheel fit on the 05 base? and work
Old 09-12-2009, 02:07 PM
ranco's Avatar
Did anyone try to fit the TSX 09 Steering wheel onto a TSX06 ?
I have not seen an answer on this one. I would be interested to know if someone tried to swap steering wheels and managed to keep all bottons and SRS working.
Old 09-12-2009, 08:43 PM
Let me help you!
SoCaliTrojan's Avatar
One thing I noticed when I had an 09 TSX loaner for 3 weeks was that it had an extra button in the bottom right of the steering wheel (for the MID). The 1st gen TSX only has two buttons, and the 2nd gen has 3. I would always get confused when I tried to hit the buttons and didn't know which one I was hitting.
Old 09-13-2009, 03:19 PM
trebor8915's Avatar
Interesting question...don't know if it's possible and I'll probably never do it.
Ranco: Why did your thread get locked?
Old 09-13-2009, 04:34 PM
LuvMyTSX's Avatar
Because the same thing is being discussed here.
Old 09-13-2009, 07:34 PM
trebor8915's Avatar
duh...
Old 09-15-2009, 12:01 AM
Dktran31's Avatar
dunno if this will work but i want that optional silver steering wheel for the 1st gen !
Old 09-16-2010, 08:25 AM
npcan2's Avatar
Revival to this thread!
Has anyone managed a steering wheel swap from a CU2 (second gen) to a CL9 (first gen)?
Anyone even know if it is possible?
Old 09-21-2010, 10:23 PM
oldguytsxer's Avatar
Why is it important to do this?
Will the car perform better?
No disrespect, but it seems like a bunch of extremely unnecessary work and thought for a next to nothing improvement?
Old 09-22-2010, 07:55 AM
npcan2's Avatar
I agree with you to some extent oldguytsxer, but imo huge body kits are monumentally useless and overpriced, as their is zero net gain to performance.
Sometimes however, it's not about the function, it is about the form of the product. If it makes the user happy, then go 4 it!
Also, you learn and have fun along the way.
but then again, thats just my .
Old 10-03-2010, 11:08 AM
PhrequenC's Avatar
up for info
Old 08-02-2018, 07:44 PM
C00TS's Avatar
Functional paddle shifters.
Necro post.
Yes, it is possible. I did it on my CL9. Everything is fully functional except the extra MID info button and navi switches (my car doesn't have navi).
Mhiral89 (04-06-2020)
Old 08-25-2018, 02:43 AM
alphaatomix's Avatar
The connector to the clock spring for the TSX is different than that of the TL-S. What did you do to make the wiring work?
Old 08-25-2018, 12:05 PM
The top is the connector for the TL-S and the bottom is the connector for the TSX that goes from the steering wheel to the clock spring
Old 08-13-2019, 09:55 AM
Swizz Beats's Avatar
what did u do with the two connectors? Did u get a type-a clock spring?
Stylinhonda
02-25-2020 09:59 AM
drkbatman
12-15-2009 02:42 AM
InspireUA5
11-07-2006 09:10 AM
countdracura
02-16-2005 06:33 PM
MasterShake
08-14-2004 08:58 AM
Quick Reply: Will a TL-S or 2009 TSX steering wheel fit 06-08 TSX?
