Wider Tires
Wider Tires
I've search and read a few posts but wanted to make sure before I actually purchased new tires.
I have stock rims and ride height setup. I was looking to get some new tires (Bridgestone RE960 AS) at 225/45/17 but was looking at the Tire Size Guide and 235/45/17 were very close to OEM. I would prefer the wider tire for handling purposes but would like to keep my MPG and speedo close to stock.
Could anyone provide any input. Thanks all.
In order to run 235's you would need a 7.5 or 8.0 wide rim. They would not work well with the OEM rims. 225's however would work ok.
But, like you already know, will deviate from overall diameter.
Originally Posted by HoRRo
You really can't get wider tire and keep your mpg. The cost of improved handling (via tires) is lower mpg due to greater rolling resistance.
I prefer all season tires b/c of Virginia's weather. It doesnt snow as bad as up state or midwest but wet traction is necessary. I think the Bridgestones are High Performance All Season. Thanks for everyone's replies. I most likely will be getting the 225/45/17 Pole Positions.
09-17-2015 09:01 PM
09-15-2015 06:44 PM
