transmission oil grey shinny color?
Old 04-01-2017, 04:40 PM
8th Gear
Hernan Betanzos's Avatar
hello i have a 2004 tsx 6 speed ,so I changed my transmission oil today and it came out grey shinny color. The first gear grinds whenever I shift into it. Could that be why it came out that way??
Old 04-02-2017, 07:19 AM
Received 16,260 Likes on 11,971 Posts
transmission oil is like engine oil...NEEDS to be changed regularly.
just sounds like you have OLD ASS FLUID FROM 2004
did the fluid change help 1st gear?
it should as new fluid has NEW fluid properties. if did not smooth out 1st gear, maybe synchros are going bad
Old 04-03-2017, 11:31 AM
8th Gear
well I haven't notice any change just yet. But I think something bigger is definitely going on I just started hearing knocking noise coming from the driver side when in gear and I let off the gas. when I take it out of gear no noise
Old 04-03-2017, 11:38 AM
maybe axle?
lol you're not giving much info...
all i can do is TRY to guess...which may or may not be what is actually happening
clutch throw out bearing ?
Old 04-03-2017, 01:18 PM
8th Gear
it only makes the knocking sound when I'm in gear. for example I'm in 3rd gear going 30 35mph approaching a red light i let off tge gas but still in gear there is a loud constant knocking noise. if I take it out of gear or press the clutch in the noise goes away. if it was one of the axles it would be making that noise no matter if it was in gear or not. I've been doing more research and it could be the differential. I hope it's not and it something much simpler like the you said the throw out bearing
Old 04-03-2017, 01:27 PM
does knocking increase with revs?
Old 04-03-2017, 01:40 PM
8th Gear
yes it does
Old 04-03-2017, 01:50 PM
interesting. but did not get me closer to a solution.
at first, was gonna say engine is knocking...but doesnt explain why it doesnt do it when clutch isnt engaged
Old 04-03-2017, 02:39 PM
8th Gear
im at a loss As well. I raised it up everything looks solid no noise. I guess it's time to pull the tranny down
