Sorry For The Typo Here Ya Go Boys
ENGINE
MEDIA
Engine Type
Aluminum Alloy in-line 4-cylinder
Displacement (liters)
2.4
Horsepower (SAE net)
200-hp @ 6800 rpm
Torque
166 lbs-ft @ 4500 rpm
Valvetrain
16-Valve, DOHC, i-VTECTM
Redline
7100 rpm
Compression Ratio
10.5:1
Fuel System
PGM-FI Multi-Point Injection
Injection System
Electronic Direct
Throttle Control
Drive-by-Wire Throttle System
Emission System
LEV-2
Cooling System Capacity
Manual: 5.4 U.S. quarts (5.3 liters)
Automatic: 7.4 U.S. quarts (7.3 liters)
Crankcase Refill Capacity, including filter
4.2 U.S. quarts (4.0 liters)
Acura Engines
Quicktime Video
VTEC
Tech-Demo
TRANSMISSION
TSX Automatic
5-Speed Automatic with Sequential SportShift,(TM) Grade Logic Control and Lockup Torque Converter
TSX Manual
Optional: Close Ratio 6-Speed Manual with Magnesium Transmission Case
Gear Ratios
TSX Automatic
TSX Manual
1st
2.652
3.267
2nd
1.517
1.880
3rd
1.082
1.355
4th
0.773
1.028
5th
0.566
0.825
6th
0.659
Reverse
2.000
3.583
Final Drive
4.440
4.760
CHASSIS
MEDIA
Body Type
Unit Body
Suspension
4-Wheel Independent Double-Wishbone/Multi-Link Rear
Stabilizer Bars, diameter (front/rear)
26.5 mm / 14.0 mm
Steering Type
Variable Power-Assist Rack-and-Pinion
Brakes: 4-Wheel Disc with ABS (front/rear)
11.8-inch ventilated/ 10.2-inch solid
Wheels
17-inch Alloy Wheels
Tires
P215/50 R17 93V All-Season Radials
Suspension
Quicktime Demo
GENERAL SPECIFICATIONS
EPA Estimated Fuel Mileage (city/highway)
Manual: 21/29* mpg
Automatic: 22/31* mpg
Fuel Tank Capacity
17.1 US Gallons (65 liters)
Recommended Fuel
Premium unleaded 91 octane or higher**
Minimum Ground Clearance (unloaded)
6.2 in (157.5mm)
Curb Weight
Manual: 3230 lbs (1465 kg)
Automatic: 3318 lbs (1505 kg)
Manual with Navigation System: 3241 lbs (1470 kg)
Automatic with Navigation System: 3329 lbs (1510 kg)
Weight Distribution (% front/rear)
Manual: 60/40
Automatic: 61/39
Headroom (front/rear)
37.8 in (960 mm) / 37.3 in (947 mm)
Legroom (front/rear)
42.4 in (1076 mm) / 34.2 in (868 mm)
Hiproom (front/rear)
54.4 in (1381 mm) / 54.4 in (1382 mm)
Shoulder room (front/rear)
55.4 in (1406 mm) / 53.5 in (1360 mm)
EPA Passenger Volume
91.0 cu. ft.
EPA Cargo Volume
13.0 cu. ft.
* Preliminary EPA mileage estimates determined by American Honda Motor Company, Inc.. Final EPA mileage estimates were not available at the time of printing. Use for comparison purposes only. Your mileage may vary.
** Gasoline with an octane number lower than 91 may be used, with reduced performance.
INTERIOR FEATURES
MEDIA
Acura Navigation System with Voice RecognitionTM (available)
360-watt Acura Premium Sound System with 6-disc in-dash CD changer and 8 speakers
Dual-Zone Automatic Climate Control System
Sport seats with perforated leather trim interior
Driver's 8-way power seat with adjustable lumbar support
Heated front seats
Leather-wrapped steering wheel
Theft-deterrent system with electronic immobilizer
Cruise control
HomeLink® system
Power moonroof with tilt feature and sliding shade
Power windows with driver's auto-down/up with auto-reverse
Power door locks with key-operated windows down/up feature
LED illuminated instruments
Titanium-finish console and door trim (Ebony and Quartz interiors)
Simulated wood-grained console and door trim (Parchment interior)
Leather-wrapped aluminum gear shift knob
Tilt and telescopic steering column
Steering wheel-mounted controls (cruise, audio and voice activation)
Front door storage compartments
Driver's and passenger's seatback pockets
Covered in-dash storage compartments
Dual trip meters
Exterior temperature indicator
Front center console with adjustable armrest, storage compartments and coin holders
Rear-seat center armrest with dual beverage holders
60/40 split fold-down rear seatback with lock
Carpeted floor mats
Stainless steel door threshold trim
Remote trunk release
Remote fuel-filler door release
Lockable glove compartment with light
Interior ambient console lighting
Progressive self-illuminating gauges
Illuminated power window switches and ignition switch
Cargo area light
Dual 12V power outlets
Dual overhead map lights
Driver's and front passenger's illuminated vanity mirrors and driver's side card holder
Sunglass holder
Digital quartz clock
Maintenance interval reminder
Dual beverage holders (front and rear)
Large Interior
Small Interior
Navigation
Quicktime Demo
EXTERIOR FEATURES
MEDIA
Power-operated, body-colored outside mirrors
Keyless entry system with remote-down windows
17-inch alloy wheels
Auto-off headlights
Body-colored door handles with chrome trim
Heat-rejecting green-tinted glass
Galvanized body panels
Body-colored front and rear bumpers
Speed-sensing, intermittent windshield wipers
Integrated rear glass antenna
Dual-outlet exhaust
Large Exterior
Small Exterior
Paint Process
SAFETY FEATURES
MEDIA
Driver's and front passenger's dual-stage airbag supplemental restraint system (SRS)
Driver's and front passenger's side airbags with front passenger's height and position sensors
Side curtain airbags
3-point adjustable-height seat belts with load limiters and pretensioners (front)
3-point seat belts at all seating positions
4-wheel anti-lock braking system (ABS)
Vehicle Stability Assist (VSA®) with Traction Control
LATCH (Lower Anchors and Tethers for Children) child-seat mounting system
Impact-absorbing crumple zones (front/rear)
Xenon High-Intensity Discharge (HID) headlights
Rear window defroster with timer
Front side-window defoggers
Side-impact door beams
Collapsible steering column
Breakaway inside rearview mirror
Automatic day/night rearview mirror
Impact-absorbing interior surfaces
Safety glass
Child-proof rear door locks
Adjustable seat headrests (front and rear outboard positions)
Non-protruding switches and controls
Automatic transmission interlock feature
Safety & Technology Demo
VSA
Quicktime Video
SRS
Quicktime Video
SRS
Interactive Video
ABS
Quicktime Video
WARRANTIES
Vehicle: 4-year/50,000-mile limited warranty*
Outer body rust-through: 5-year/unlimited-mile limited warranty*
Accessories: 4-year/50,000-mile limited warranty**
2.4-literI-4 engine: No scheduled tune-ups required for 110,000 miles***
* Ordinary maintenance items or adjustments, parts subject to normal wear and replacement, and certain other items are excluded. See your Acura dealer for the terms and conditions of limited warranties.
** When installed at the time of new-vehicle delivery.
*** Does not apply to fluid and filter changes or periodic inspections. Please refer to the maintenance section of your owner 's manual to determine all appropriate maintenance intervals.
INTERIOR ACCESSORIES
MP3 Player or Cassette Player
All-Season Floor Mats, Front & Rear
Steering Wheel, Wood-Look & Leather
Interior Trim, Metal-Look
Interior Trim, Light Wood-Look
Trunk Tray
Luggage Net
Engine Block Heater
EXTERIOR ACCESSORIES
Moonroof Visor
Car Cover
Full Nose Mask
Door Visors
Door Edge Trim
Wing Spoiler
Front Under Body Spoiler
Side Under Body Spoiler
Rear Under Body Spoiler
17" Aluminum Alloy Wheels (3 designs)
Splash Guards
Fog Lights
Chrome "A" wheel emblems - set of 4
Gold "A" wheel emblems - set of 4
Wheel Locks
Gold Emblem Kit
SCHEMATICS
MEDIA
Engine Type
2.4
200-hp @ 6800 rpm
Torque
Valvetrain
Redline
7100 rpm
Compression Ratio
10.5:1
Fuel System
Injection System
Electronic Direct
Throttle Control
Emission System
LEV-2
Acura Engines
Quicktime Video
VTEC
Tech-Demo
TRANSMISSION
TSX Automatic
TSX Manual
Gear Ratios
TSX Automatic
TSX Manual
1st
2.652
3.267
2nd
1.517
1.880
3rd
1.082
1.355
4th
0.773
1.028
5th
0.566
0.825
6th
0.659
Reverse
2.000
3.583
Final Drive
4.440
4.760
CHASSIS
MEDIA
Body Type
Unit Body
Suspension
26.5 mm / 14.0 mm
Steering Type
Wheels
Tires
Suspension
Quicktime Demo
Manual: 21/29* mpg
Fuel Tank Capacity
Recommended Fuel
6.2 in (157.5mm)
Curb Weight
Manual: 60/40
Automatic: 61/39
91.0 cu. ft.
EPA Cargo Volume
13.0 cu. ft.
INTERIOR FEATURES
MEDIA
Heated front seats
Cruise control
HomeLink® system
Dual trip meters
Carpeted floor mats
Cargo area light
Sunglass holder
Large Interior
Small Interior
Navigation
Quicktime Demo
EXTERIOR FEATURES
MEDIA
Auto-off headlights
Dual-outlet exhaust
Large Exterior
Small Exterior
Paint Process
SAFETY FEATURES
MEDIA
Safety glass
VSA
Quicktime Video
SRS
Quicktime Video
SRS
Interactive Video
ABS
Quicktime Video
WARRANTIES
Trunk Tray
Luggage Net
Engine Block Heater
Moonroof Visor
Car Cover
Full Nose Mask
Door Visors
Door Edge Trim
Wing Spoiler
Splash Guards
Fog Lights
Wheel Locks
Gold Emblem Kit
SCHEMATICS
Registered AssHat
Re: Sorry For The Typo Here Ya Go Boys
Originally posted by ACURAVVON
ENGINE
MEDIA
Engine Type
2.4
200-hp @ 6800 rpm
Torque
Valvetrain
Redline
7100 rpm
Compression Ratio
10.5:1
Fuel System
Injection System
Electronic Direct
Throttle Control
Emission System
LEV-2
Acura Engines
Quicktime Video
VTEC
Tech-Demo
TRANSMISSION
TSX Automatic
TSX Manual
Gear Ratios
TSX Automatic
TSX Manual
1st
2.652
3.267
2nd
1.517
1.880
3rd
1.082
1.355
4th
0.773
1.028
5th
0.566
0.825
6th
0.659
Reverse
2.000
3.583
Final Drive
4.440
4.760
CHASSIS
MEDIA
Body Type
Unit Body
Suspension
26.5 mm / 14.0 mm
Steering Type
Wheels
Tires
Suspension
Quicktime Demo
Manual: 21/29* mpg
Fuel Tank Capacity
Recommended Fuel
6.2 in (157.5mm)
Curb Weight
Manual: 60/40
Automatic: 61/39
91.0 cu. ft.
EPA Cargo Volume
13.0 cu. ft.
INTERIOR FEATURES
MEDIA
Heated front seats
Cruise control
HomeLink® system
Dual trip meters
Carpeted floor mats
Cargo area light
Sunglass holder
Large Interior
Small Interior
Navigation
Quicktime Demo
EXTERIOR FEATURES
MEDIA
Auto-off headlights
Dual-outlet exhaust
Large Exterior
Small Exterior
Paint Process
SAFETY FEATURES
MEDIA
Safety glass
VSA
Quicktime Video
SRS
Quicktime Video
SRS
Interactive Video
ABS
Quicktime Video
WARRANTIES
Trunk Tray
Luggage Net
Engine Block Heater
Moonroof Visor
Car Cover
Full Nose Mask
Door Visors
Door Edge Trim
Wing Spoiler
Splash Guards
Fog Lights
Wheel Locks
Gold Emblem Kit
SCHEMATICS
ENGINE
MEDIA
Engine Type
2.4
200-hp @ 6800 rpm
Torque
Valvetrain
Redline
7100 rpm
Compression Ratio
10.5:1
Fuel System
Injection System
Electronic Direct
Throttle Control
Emission System
LEV-2
Acura Engines
Quicktime Video
VTEC
Tech-Demo
TRANSMISSION
TSX Automatic
TSX Manual
Gear Ratios
TSX Automatic
TSX Manual
1st
2.652
3.267
2nd
1.517
1.880
3rd
1.082
1.355
4th
0.773
1.028
5th
0.566
0.825
6th
0.659
Reverse
2.000
3.583
Final Drive
4.440
4.760
CHASSIS
MEDIA
Body Type
Unit Body
Suspension
26.5 mm / 14.0 mm
Steering Type
Wheels
Tires
Suspension
Quicktime Demo
Manual: 21/29* mpg
Fuel Tank Capacity
Recommended Fuel
6.2 in (157.5mm)
Curb Weight
Manual: 60/40
Automatic: 61/39
91.0 cu. ft.
EPA Cargo Volume
13.0 cu. ft.
INTERIOR FEATURES
MEDIA
Heated front seats
Cruise control
HomeLink® system
Dual trip meters
Carpeted floor mats
Cargo area light
Sunglass holder
Large Interior
Small Interior
Navigation
Quicktime Demo
EXTERIOR FEATURES
MEDIA
Auto-off headlights
Dual-outlet exhaust
Large Exterior
Small Exterior
Paint Process
SAFETY FEATURES
MEDIA
Safety glass
VSA
Quicktime Video
SRS
Quicktime Video
SRS
Interactive Video
ABS
Quicktime Video
WARRANTIES
Trunk Tray
Luggage Net
Engine Block Heater
Moonroof Visor
Car Cover
Full Nose Mask
Door Visors
Door Edge Trim
Wing Spoiler
Splash Guards
Fog Lights
Wheel Locks
Gold Emblem Kit
SCHEMATICS
He
He
I
am
such
a
post
whore.
Oh,
and
I
B
T
L
