Seafoam
Old 02-03-2012, 07:41 AM
Aguilucho del Cibao!
Duriisimo's Avatar
Seafoam
I did the treatment yesterday, about 5oz in the vacum line and 5oz in the gas tank. Not as much smoke as I anticipated. I guess thats a good thing. Very easy to do.
Old 02-03-2012, 01:58 PM
kbh
kbh's Avatar
My understanding is that you are also supposed to pour 1/3 of the bottle into the crankcase
Old 02-03-2012, 07:12 PM
feuss2's Avatar
It doesn't matter. Because it's magic.
Old 02-04-2012, 01:31 AM
deadlyklappy12887's Avatar
complete waste of money...does absolutely nothing...youre lucky you didnt damage your car
Old 02-04-2012, 07:12 AM
Rich and Famous
EL_PIC's Avatar
++ 1.
The true way to clean is to remove parts and clean them in solvents and or sand blast.
Pour your problems away is kinda like Dr. Wizzo's Magical Fat Removal Exlir.
Often the pour your problems away solvents may help some areas but foul others like hoses.
Buyer Beware !!
Old 02-04-2012, 11:54 AM
psteng19's Avatar
How many miles do you have?
I did mine at 75k and had a good amount of smoke.
Old 02-04-2012, 01:32 PM
kixo's Avatar
Would you put Techron by Chevron in the same category? That product seems more legitimate, but could just be a marketing gimmick.
Old 02-05-2012, 04:14 PM
Old Guy
Simba91102's Avatar
It's all snake oil
Old 02-05-2012, 07:22 PM
feuss2's Avatar
Originally Posted by Simba91102
It's all snake oil
That's no way to talk about sea foam. It's magic.
Old 02-05-2012, 10:01 PM
youre gonna burn smoke either way. the "seafoam" is a petroleum product. the smoke produced tells you nothing about whether your engine was "dirty" or "clean".
and feuss i love you! toooooo funny
Old 02-05-2012, 11:42 PM
Early Shifter
ohsixMTee's Avatar
Waste of money but if it makes you feel better than go for it. I would NOT put it in the crankcase, fuel tank only if you choose to use it.
Old 02-06-2012, 12:23 AM
sixwhip14's Avatar
I've used it in my civic's b16. If you put it in the crankcase, it's suppose to be right before you do an oil change. The reason is because it thins out the oil a bit. And if it does loosen contaminants in the crankcase, you wouldn't want to keep running your engine without cleaning it out. I really don't think it did anything btw.
I would never use or put seafoam in a k series engine with our timing chain possibly stretching issues.
Old 02-06-2012, 01:55 AM
kewlliljethro's Avatar
I read somewhere that seafoam fouls up your spark plugs as well. So if you're gonna do it, do it before an oil change and before you plan to change your spark plugs.
Controversial topic, this seafoam is.
Old 02-07-2012, 08:46 PM
this is true.
also true.
we've hit the tri-fecta!!!!!!
Old 02-09-2012, 11:12 AM
MegademiC's Avatar
I thought it was good for cleaning out the fuel injectors. I had a slight hesitation when cruising at 2k rpm. Just got done using seafoam(in gas tank) and after I change my oil and check plugs, and air filter, I'll see if its better (could be the air filter too though). I just bought the car with 150k miles on it and wanted to make sure everythings g2g.
Old 02-09-2012, 06:09 PM
Mdumanski01's Avatar
Sea foam doesn't work huh.. Lol okay.. I've seen it, I've witnessed it!!! And it worked.. And by the way that was on my rsx type s, 130k miles. K20 engine!
Idles better, sounds better at idle.. Isn't as loud at idle..isn't loud in the morning anymore.. Smoother everything!!! I'm not saying everyone is going to see great results but I did 100%..
And the smoke is from carbon buildup right, so the more buildup you have the more smoke.. I had a lot of smoke come out!! I also got an oil change within 60 miles after..
I just got an 05 TL, and when the time comes for an oil change, guess what
Old 02-10-2012, 10:34 AM
Early Shifter
ohsixMTee's Avatar
^lol Rock on bro. Too many factors control the behavioral improvements you listed. Seafoam is magic in a can. You're better off using Lucas fuel additive every so often.
acuratl26
04-23-2020 07:30 PM
IlliniAcura
09-19-2015 09:31 PM
klepto
1G CL DIY & FAQ
36
09-25-2009 01:55 AM
EPS CL
06-02-2009 11:16 PM
manteuffel
03-12-2006 11:12 PM
Quick Reply: Seafoam
