Replacing Catalytic Converter on 05 TSX
Old 12-04-2014, 10:42 PM
8th Gear
Mhogan4491's Avatar
Howdy all!
So I recently purchased my 05 AT TSX with about 90k on it and today it sounded as if the muffler became detached and sure enough, the catalytic converter and midpipe (?, sorry im a newb forigve me if I'm using the wrong terminology) were no longer attached. I checked it out from underneath, thinking I would only need a new gasket and some new nuts. Turns out the bolt threads are almost completely stripped, leaving me in the market for a new Catalytic Converter. Does anyone have any suggestions on which one and where I should buy it? I have looked on rockauto.com and a couple of other random google sites. Also, is there a DIY thread for what I'm doing? I tried searching the site and through google but was unable to find one
Thank you in advance!
Old 12-05-2014, 07:57 AM
TexasHonda's Avatar
If you have damaged bolt threads on catalytic converter studs, it may be possible to replace stud/s by knocking out old stud and pressing in new.
Even if stud is welded in place it may be worth paying someone to replace the stud. A new OEM cat is costly and worth some salvage effort.
Any video on Honda/Acura catalytic converter replacement should provide some guidance.
You will need to elevate front and rear to have adequate working room. I used front ramps and rear jack stands.
Here's one example:
good luck
Old 12-05-2014, 02:10 PM
8th Gear
Mhogan4491's Avatar
Bolts/studs are welded on there, how much would it cost to have them taken out? I appreciate the quick response and also another quick question, do i absolutely need OEM or is it safe to buy another brand? Thanks again for your help!!
Old 12-06-2014, 07:39 AM
TexasHonda's Avatar
I've never heard anyone say that aftermarket converters are as good as OEM. Problem is OEM is $$ ($700). That's why I suggested trying to salvage. Repair (if you supply studs) should be $ $25-$50. I believe the studs are pressed into a hole and then welded to hold in position.
good luck
Old 12-09-2014, 09:18 AM
Former Sponsor
ExcelerateRep's Avatar
If you're looking to get a catalytic converter with more air flow check out our XLR8 High Flow Cat. It will bolt in as a direct replacement to your stock cat and offer increased air flow.
XLR8 High Flow Cat - Excelerate Performance - Japanese and European Performance Specialists!!
Old 12-15-2014, 06:53 PM
tsx_boy's Avatar
I have a oem cat conversation for sale dm
Old 05-27-2015, 01:00 PM
netsx04's Avatar
I'm experiencing the exact problem on my '04 TSX (w/ 170k). How much did the repair cost you?
cycdaniel
12-17-2019 10:58 AM
orkoTL
4G TL Problems & Fixes
107
09-28-2017 09:12 AM
BlkTxAcuraTypeS
10-18-2015 08:05 PM
Skirmich
09-15-2015 06:41 PM
jpm3071
NY/NJ
09-07-2015 08:25 AM
Quick Reply: Replacing Catalytic Converter on 05 TSX
