Need Replacement Wheel Lock Key
mrgold35
Is the standard OEM wheel lock sold by Acura? You can go to any Honda or Acura dealership for removal or replacement. Pretty much 99% of tire shops will have a key for the OEM wheel lock if you just want to remove and replace with a regular lug nut. The only issue you might have if you want to replace the OEM wheel lock with aftermarket lock is OEM wheel lock are made for OEM wheels with ball (rounded) lugs and most aftermarket wheel locks are usually tapered/cone (straight sided) design. Cannot mix ball and tapered/cone lug nuts if the OEM rims require ball lugs.
justnspace (01-22-2018)
StonedCL
11-15-2005 07:46 AM
mrsteve
2G CL Transmission Recall Q & A
01-24-2005 02:22 PM
