License Plate LED DIY
I couldn't find any real guides with pictures when I was looking for the license plate LED replacement. So I hope this helps those that still want to change those lights.
Required Equipment
1. Phillips head Screw Driver
2. 15 mins
Step 1.
Remove the 3 that line the top of the trunk shown in picture 1.
Step 2.
Then that rectangular rubber piece that is circled in picture 1 has 3 rubber/ plastic tabs. You will need to lift the left most tab and shift the last 2 to the left and the piece will slide out. In picture 2 you will see how it looks after that rubber piece is removed. Do the same to the other side and the lining will come right off.
Step 3.
Now stick your head in and you will see the 2 lights and what holds them in. Squeeze the 2 sides circled in picture 3 and they will slide right out(replace oem light with led). Repeat for the other side and your done.
I will try to get a picture of how it looks before you pull it out.
The following are the before and after pictures. No night time pics as I just put them in today during my lunch break.
Before
After
Difference
![](http://i83.photobucket.com/albums/j313/mrpeeng/compare.jpg)
Note: I know my license plate screws are different but don't take any points away because of it, new license plate frame is coming.
Required Equipment
2. 15 mins
Step 1.
![](http://i83.photobucket.com/albums/j313/mrpeeng/screws.jpg)
Step 2.
![](http://i83.photobucket.com/albums/j313/mrpeeng/lock.jpg)
Step 3.
![](http://i83.photobucket.com/albums/j313/mrpeeng/light.jpg)
Before
![](http://i83.photobucket.com/albums/j313/mrpeeng/before.jpg)
After
![](http://i83.photobucket.com/albums/j313/mrpeeng/done.jpg)
Difference
which bulbs did you use and did the fit properly. I have the 9 leds from tec-toyz and they are real tight.
also I didn't have to take off the rubber gromments I just moved the interior fabric around them
You didnt need to take off the rubber. Just yank around the rubber, and it slides right off.
I used the 1 high powered led. Its as small as the oem wedge bulb and its not tight at all.
Scroll down to the bottom WLED-WHP
High powered led
Compare the size of that to ur 9 led bulb. Do you have any pictures of your license plate light at night so i can compare to mine?
High powered led
AlwysCleanURArely c ASpec
I agree.. looks good though
Hailing from the 3-0-5
Ebay LEDs
I bought mine through tec_toyz on Ebay for about $16 delivered. I have the Wide Angle Hi-Power 1 WATT LED bulbs and they look great. Had them on for about 2 days (nights) and have received raving comments from jealous onlookers
! Warning, the right light was a B*&$% to change.
![](http://img97.imageshack.us/img97/8637/tsxbackrs1.jpg)
did they fit in tight or just like the OEM bulbs. the 9 leds are very tight
hmm. I may have to switch to the 1 wat led, the 9 led bulbs that I got from him fit the socket but they are long and a tight fit and don't really shine the light down.
mmmmmm....
Originally Posted by KmanianTSX
The socket itself was a tight squeeze, but the bulb fit the holder perfectly. They are reaaaaallly small. I almost thought that I had gotten gyped!
Originally Posted by S14 n Tsx
did they came as package? tail lights, dome lights, door lights. and license lights.
i dont kno if it just my car but i went through 3 sets of led on my license plate. its always the right side that always fu*k up. 1 set was the high flux LED, which is the new led's. its a little brighter. but this time it only last for bout 2 weeks and it started flickering. didnt slam the trunk at all. just closeed it by pushing down on the trunk. my last 2 led last me bout 1-3months i think and it started flickering. i think other ppl had the same problem. anyways i'm sticking with regular bulb.
Boost Junky
i just picked these up from tek toyz as well. Whats the interior LED package that you guys are talking about? Are you talking about the map lights and puddle lights on the doors?
the lights would be:
A. The lights in the door
B. The map lights (front of the car)
C. The dome light (back seat)
You could also pick up bulbs for your trunk and license plate.
Originally Posted by drunkenbuda
![rtfm](https://acurazine.com/forums/images/smilies/rtfm.gif)
![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
Boost Junky
Ride slow homey>>What part of the Island you from? I live here too
Originally Posted by simplyscion
I already bought the ones for the license plate from tec toyz but I should get the ones for the trunk. Does anyone know off the top of their head what the LED bulb sizes are for the doors, map lights and dome lights(guessing the last 2 are a 194) and also the trunk lights? Thank you for the help.
Boost Junky
Originally Posted by visuelz
What's the size for the license plate?
Swinger, just ask Lindy
A bit of searching will do wonders...
https://acurazine.com/forums/showthr...6&page=6&pp=25 Go to post #129.
http://mysite.verizon.net/resow073/TSXLED/
http://www.sylvania.com/ConsumerProd...lacementGuide/
High powered led
High powered led
I bought and installed the same LED bulbs and I gotta say I'm impressed. They're much much brighter than the LED bulbs that I replaced.
921-X12
bulb for trunk
Nice replacement, just made me want to pick up a pair of those wedge bulbs from Fizz on the Northern Blvd or check it out in Mitsuwa. You bought your car at Paragon? I didn't like their salesman there.....
You can get to those bulbs from the rear of the car (ie with the boot closed). You just pull down the trim near the boot release and then slide the globe covers off. Takes less than 1 minute.
