Jacking Points
Old 09-10-2004, 02:58 AM
tommy626's Avatar
Jacking Points
Would like to change oil/filter on TSX. Are there jacking points on front and back so I can get floor jack in and then get jack stands on sides?
Old 09-10-2004, 04:56 AM
biker's Avatar
Welcome to the site.
Old 09-10-2004, 08:06 AM
STL
STL's Avatar
You have an owners manual, right?
Old 09-10-2004, 08:20 AM
Nick250's Avatar
When I used to do my own oil changes I used a "ramp" that I could drive up my front or rear wheels on that gave me about a foot extra height. I got it from Sears and it was pretty inexpensive.
Nick
Old 09-10-2004, 08:40 AM
Deelover's Avatar
One jack needed. One jack stand ( Saftey ) Jack up the front passenger side. Remove passenger side tire. Easy access to oil plug and most important, easy access to the oil filter. With the tire on the oil filter is a B**** to get at. I found that the pliers type oil wrench works best.. as I have tried the cap wrench and the band wrench. The cap type slips and its a tight fit for the band type. There is a portion of exposed frame in the front that you can use a floor jack and jack up the front evenly if so desired.
Old 09-10-2004, 09:01 AM
tommy626's Avatar
Owner's manual just describes side jack points, not front and back.
Old 09-10-2004, 09:09 AM
Registered AssHat
Lung Fu Mo Shi's Avatar
Those are the only ones there. There's no fram under the engine.
Old 09-10-2004, 09:54 AM
STL
STL's Avatar
That seems odd to me too! Every Honda I have owned has had 4 side jack points in addition to one front and one rear jack point.
Old 09-10-2004, 11:52 AM
gogozy's Avatar
can someone tell me... i am confused.. where is the front jack point? thanks..
by the way, you can access oil filter from the top.
Old 09-10-2004, 12:02 PM
Bye TSX, hello domestic?
xizor's Avatar
there are arrows on the underbody plastic cover that point to the hacking point I believe, or are thoes the towing points? jacking the front wasn't the useful to me since we have a lot of ground cleranece and suspension travel. the side works much better IMO w/ some jackstands
Old 09-10-2004, 12:26 PM
tommy626's Avatar
If you raise from the side, how can you get the jack stand in
Old 09-10-2004, 12:27 PM
tommy626's Avatar
How you get oil filter from the top?
Old 09-10-2004, 12:30 PM
Just dial 1911
joerockt's Avatar
I have yet to see a pic of someone removing the oil filter from the top. Until then, I say it cant be done.
Besides, doing it from the right side wheel well is very easy.
Old 09-10-2004, 12:32 PM
gogozy's Avatar
if you down engine bay from pasengar side, near the exhaust shield, you shall see the "blue" oil filter. be careful of exhaust manifold can be very hot and, don't scratch paint when lean on the side.
Old 09-10-2004, 12:35 PM
gogozy's Avatar
how can i upload pics?
Old 09-10-2004, 12:36 PM
Just dial 1911
joerockt's Avatar
Take a pic showing yourself doing this. I know where the filter is and I've seen it from the top, but unless your some sort of wrist/arm contortionist, I dont see a way to reach under the manifold to grab it.
So like I said, unless someone has a pic of them doing this,
Edit: First one to post a pic gets rep! Hows that for incentive
Old 09-10-2004, 12:39 PM
Just dial 1911
joerockt's Avatar
You have to host it somewhere. Try here and once you have the pic up, right click on it, go to properties and copy the link the pic is at. Come back here, click on insert image and paste the link...done...
Old 09-10-2004, 12:46 PM
gogozy's Avatar
okay, in that case probably another 10,000km i did it at 10,000km and will get free type B services at 16,000km from dealer. right now my wife ask me to stay away from the car because we got a 2 month old to look after
use a socket type oil filter remover, and it's quite easy. and hand tight the filter. i am only 5'6" tall, but then i don't have a buhdda belly against body panel when i lean over to remove the thing , oh, a little chair may help
look like i got to do it so people will believe me okay la, i will try sneak out to snap some pic if i can!!
Old 09-10-2004, 01:12 PM
JTso's Avatar
The under body splash guard has a BIG ASS arrow pointing to the front center jack point. There is a jack point for the rear as well. The service manual has the complete jack point locations.
Old 09-10-2004, 01:31 PM
DEVO's Avatar
where you jack the car up and where you can put stands are two different points. yes you can put jack stands at the jack point but sometimes that is not possible... the question is where else can you safely put stands. the answer is on the rails. make sure it's the rails and not the floor otherwise you are in for a big surprise.
Old 09-10-2004, 01:33 PM
DEVO's Avatar
oh yeah... the owner's manual will not tell you this. just enough info to change a tire.
Old 09-10-2004, 01:50 PM
gogozy's Avatar
thanks! i will try no suprise hehe
Old 09-10-2004, 02:38 PM
biker's Avatar
I wonder if there's a pic floating on the net showing the after effects of a badly placed jack stand?
Old 09-15-2004, 12:11 PM
DEVO's Avatar
one more thing. if you are jacking your car up on a lift. make sure you do so in an even manner. there have been cases where the windshield can crack because too much stress was placed on one side of the car. this rarely happens on a modern car, it happens more on a hobby car, classic car, etc..
FYI... most lifts in garages can't access the jack points specified by the owner's manual of most cars. hence the lifts will be placed on the rails of the car. Usually the front side gets the rails where the rear portion gets the jack points.
Old 11-23-2004, 11:06 PM
TypeTSX's Avatar
Old 11-24-2004, 06:02 AM
Moderator Alumnus
sauceman's Avatar
Red X...
Old 11-24-2004, 06:47 AM
John Starks - The Dunk
yuhoo22's Avatar
what exactly is meant when you guys say rails. I had a tough time actually rotating my tires a few weekends ago because I couldn't find a place for the jack stands. Pics would be nice if you guys can snap one or two. Much thanks.
Old 04-17-2006, 03:49 PM
shitbox's Avatar
quick question guys, i was trying to jack up the rear of the car today cause i was trying to adjust the rear ride height on the tein ss. I used the rear bumper jacking point but somehow the jack couldn't go any higher so i couldn't place my jack stands on the side jack points.
Should i place the jack at the side jack points and then place the jack stands at the rail (its on the inner of the side jack point and it looks like the flame of the car).
Sorry for the stupid description, its so not clear. haha
Do you guys know what i'm talking about?
any feedback would be greatly appreciated.
Old 04-17-2006, 05:12 PM
shitbox's Avatar
maybe this is a previous question that another member asked and answered. i did some search about this but i'm not too clear about this. I'm afraid that i would kill myself if the jack stands or jack aren't properly placed..
Old 04-23-2006, 01:45 PM
dP-
dP-'s Avatar
Put some wood under your jack to add some additional clearance to it. Try using plywood, as it doesn't crack.
Old 03-29-2007, 03:43 PM
super4's Avatar
anyone got a pic of the rear jack point?? (not the side jacking rails)
Old 03-29-2007, 03:49 PM
dom
dom's Avatar
I couldn't find the damn thing on Monday night.
Old 03-30-2007, 06:20 PM
Let me help you!
SoCaliTrojan's Avatar
How about a bad set of jackstands?
Old 03-30-2007, 06:22 PM
Let me help you!
It's right in the center...between the mufflers...there are arrows pointing to it (it looks like a bar to hook something onto). If that's not it, then I sure could have gotten hurt a couple of times before...lol
Old 03-30-2007, 09:36 PM
talk about mudflaps....
dereksmalls's Avatar
https://acurazine.com/forums/showthr...Jacking+points
Old 11-04-2016, 09:56 AM
GreenMM's Avatar
Zombie old post but I could not resist.
Is this a joke? Does anyone actually have problems changing the oil filter from the TOP of the car??
Geez... try owning a 3rd Gen Integra for 20 years and doing all your oil changes from the top.
That's one of the best things about the TSX (and Accords) - how easy it is to do oil changes (from the top) and all the S P A C E around the engine.
My two cents, rant done :P
Mike734
12-10-2021 01:25 PM
navtool.com
3G MDX (2014-2020)
32
01-20-2016 11:43 AM
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
Quick Reply: Jacking Points
