I think the door lock actuator went - AcuraZine - Acura Enthusiast Community
Notices
Old 01-19-2019, 06:53 PM
Registered Member
Acura743's Avatar
Angry I think the door lock actuator went
I cant tell what this problem is but based off google searches it seems that this is a big problem that acura just didnt care enough to do a recall.
So basically my driver side car door will not lock with the key anymore, the rear driver side stopped working aswell but i didnt care as much. This is actually a problem as when i close my car door and start the car, the dash indicates that the driver side door is still open and when i press down the door lock it goes right back up along with the car lock button on the side near the power windows wont lock the door.
Thank you!
Acura743 is offline
Old 01-20-2019, 01:34 PM
Registered Member
Reorge's Avatar
This happened on my TL at about 75K miles. Doors wouldn't lock with remote. I had to replace the door lock actuator. I used metallic tape to reseal the plastic behind the door panel.
This post also list other posts.
https://acurazine.com/forums/4g-tl-p...orking-956849/
Reorge is offline
The Following User Says Thank You to Reorge For This Useful Post:
Acura743 (01-20-2019)
Old 01-20-2019, 04:50 PM
Registered Member
Acura743's Avatar
WAIT I FIXED IT.
So ever since i got the car the Interior lights fuse always randomly pops. I figure this has to do with the aftermarket radio that was installed so i just bought a pack of 100 when it was on sale on ebay($7) and keep them in my cars trunk. So today it popped and i went to go open the fuse box when i saw on the diagram that is had the door lock fuse as well. Well this got me thinking maybe this issue is related to the fuse? Sure enough i took the fuse out for the door lock it was not blown so i put it back in and it worked! The door locks and it dosent do the same issue that it was before!
Hopefully this helps someone, before they run to change the actuator. It looks like a tedious DIY.
BEFORE
Spoiler
Door was closed but it indicated it was open
Would not go down even if i pushed it, went right back up
AFTER
Spoiler
After taking out fuse 8 (20A) and reinserting it, problem was resolved
it closes now and the light is gone
Acura743 is offline
Old 01-20-2019, 04:54 PM
Registered Member
Acura743's Avatar
Also heres the CABIN FUSE BOX DIAGRAM
Spoiler
Acura743 is offline
palidanx
1G TSX Problems & Fixes
01-23-2011 03:39 PM
65 Fury Convert
1G CL DIY & FAQ
06-26-2008 08:54 PM
bojangling
Second Generation CL Discussion (2000-2003)
05-27-2008 07:19 AM
Jarvo1
First Generation TSX Discussion (2004-2008)
02-14-2008 08:35 AM
RSZero1
First Generation CL Discussion (1997-1999)
02-11-2008 08:45 PM
Quick Reply: I think the door lock actuator went
