The HT-Spec TSX Gets A The Power Steering Hose Recall Done!
Old 06-29-2010, 08:24 PM
Former Sponsor
MrHeeltoe's Avatar
Read up on our experience here:
http://www.heeltoeauto.com/pitboard/?p=192
Here is a snippet for you.
Originally Posted by mrheeltoe
Happily responding to the recall letter I received from Acura regarding the power steering hose recall, I took the HT-Spec TSX in for SERVICE at my local dealer, Acura of Mission Viejo.
Here is a down-loadable PDF of the service bulletin regarding this recall. Read it. Seems simple. Pay particular attention to the stuff about draining the fluid and then refilling with new fluid.
Here we are sitting in the service drive entrance. You are right to think that the HT-Spec TSX was most likely the best looking car to roll through on this particular day. Expecting of course and NSXs that might have strolled through.
The best place to do last minute DIYs is the service drive of your local Acura dealer.
I like to take a little time at this stage of any labor job I like to take a look at the effected areas of the work. In this case, the high-pressure power steering hose runs in between the Alutec Tower Brace and the Fastline Performance Carbon Spark Plug Cover. I decided it was best to remove them before releasing my ride to the dealership in an effort not to tempt fate and risk damage to over $300 in HT-Spec parts.
Marcus
Old 06-29-2010, 09:25 PM
Needs more Lemon Pledge
stogie1020's Avatar
Received 2,000 Likes on 1,173 Posts
FYI my dealership pulled the same crap with the PS fluid and the recommendation that it be "flushed" because it's dirty. How the hell is it dirty if you just replaced it all in the recall work? Which time were you lying dealership? EIther you swapped it all out and are lying telling me it's now dirty or you lied when you said you did the recall service correctly and replaced the 2 "units" of PS fluid. BTW. how much total PS fluid should the car take, assuming it's empty? 2, Or more?
Old 06-29-2010, 11:05 PM
samnguyen's Avatar
Same here too, I hated my local stealer; that's y I took my car to a dealer about 30 miles away from my house to get all the services done there. Last time I dropped off my car at the local stealer (where I bought the car from) to get some interior parts replaced and they f***k it up.
Old 06-30-2010, 09:28 AM
Former Sponsor
MrHeeltoe's Avatar
It probably should only take 2 bottles if that is what is billed out. I am going to do a DIY soon to verify.
Old 06-30-2010, 12:10 PM
Jottle's Avatar
I had the ps recall work done yesterday. I swear they used zipties on the new hose that connects towards the back of the engine. Those clamps look different than the ones I have in my car.
Old 06-30-2010, 05:51 PM
Former Sponsor
MrHeeltoe's Avatar
this is depressing. Seeing these comments and the others posted in the blog.
Old 06-30-2010, 06:05 PM
Someone stole "My Garage"
curls's Avatar
Any stealership that recommends a PS fluid change, let alone a flush, is ROBBING you. As per the engineers who designed the car, the PS fluid is a LIFETIME fluid. Now I don't believe in lifetime fluids for anything, so I changed mine myself a few months ago (160,000km / 100,000 miles). Its not hard, I believe it took 2.5 bottles (buy 3 to be sure, bring one back if you don't need it). You will want to have some kind of hose and clamp to extend the return hose into a suitable container.
The steps are simple:
1. Disconnect return (top) hose. Extend it with a hose + clamp, into a glass or suitable jar.
2. Turn on car.
3. Turn steering wheel lock-to-lock a few times.
4. Check fluid level in reservoir - top up now.
Repeat 3 and 4 until the fluid coming out of the return hose is off-clear (very slight yellow colour, almost clear). This is where a small container helps as it lets you see the colour of the fluid coming out before it gets mixed with all of the other old fluid.
5. Once fluid is satisfactorily fresh, reconnect return hose to reservoir. Top up fluid to MAX level.
6. Replace reservoir cap, grab a beer, drink.
Old 06-30-2010, 08:42 PM
Daffunda's Avatar
Internet is wonderful. Good to go in there armed with information.
Old 06-30-2010, 09:37 PM
Jottle's Avatar
Yep. There are zip ties on mine. It doesn't look like one full hose as in marcus' pictures. My rubber hose is cut in two in the middle and there's a clamp that's attached there. The middle sections of the rubber hose have zip ties presumably to keep them on. Anyone else's look like this? I'll post pics soon.
Old 07-01-2010, 02:41 AM
acura_ak's Avatar
I also saw zip ties on my hose too....whew, I thought it was just my dealership that was cheap. So I guess it's normal.
Old 07-01-2010, 03:16 PM
Jottle's Avatar
Here are some pictures of my recall job. Marcus' probably looked different as a result of some mods I have no idea. I may start a new thread if I don't get many responses. Does your car look like this as well?
Old 07-01-2010, 05:07 PM
Jottle's Avatar
Could be the same dealership. I went to Acura Kearny Mesa.
Old 07-01-2010, 07:27 PM
Former Sponsor
MrHeeltoe's Avatar
That is how they all are. That is how the new, updated part comes.
Old 07-01-2010, 07:28 PM
Former Sponsor
MrHeeltoe's Avatar
??? Our hoses are the same. There is no cut in the tube dude It looks like like the plastic sheath around the hose was trimmed back on your car for some reason. Probably because the mechanic realizes it doesn't need to be there.
Old 07-02-2010, 02:40 AM
acura_ak's Avatar
Yep, the pics you posted up is exactly how mine looks like. I went to a different dealership though. I just thought it was weird for them to use zip ties.
Old 07-02-2010, 07:03 AM
NwTSXmt's Avatar
Zip ties are common in the auto industry today...sad fact but its true
Old 07-02-2010, 10:36 AM
still plays with cars
nbtx's Avatar
That is the ugliest mess - Honda should be ashamed. I'll just leave mine as is and take my chances. The next owner can deal with it instead.
Old 07-02-2010, 11:12 AM
Former Sponsor
MrHeeltoe's Avatar
This is what you get with a sue-happy society :/
Old 07-02-2010, 01:06 PM
nbtx's Avatar
It looks like their band-aid fix is to sleeve the new hose so that when it fails, the sleeve diverts the fluid away from the exhaust manifold so your used-to-be nice TSX does not go up in flames. I'm underwhelmed.
Old 07-02-2010, 01:15 PM
Former Sponsor
MrHeeltoe's Avatar
Nice analysis! Lol
Old 07-03-2010, 05:49 AM
it's a car-drive it
nj2pa2nc's Avatar
I try to get the service on my 06 tsx done when I am in NJ (the dealer is in Pa-125 miles). I go to the one near me for the annual state inspection and when I need the cars oil changed and can not make it to Pa. (Not into doing any car maintenance). I had the oil changed a few days ago in NC. They mentioned the power steering recall and then advised the car needed the Power steering flush. I declined both.
TL-Rocket
04-29-2023 02:33 AM
Yikes
05-03-2021 04:29 PM
mike from annapolis
05-07-2017 08:21 PM
nash3222
09-10-2015 09:46 PM
Quick Reply: The HT-Spec TSX Gets A The Power Steering Hose Recall Done!
