How to remove center console
Old 02-17-2009, 11:13 PM
transit6404's Avatar
Hey guys,
My heated seat lights are out and I want to take my center console apart.
I did do my homework and searched all over the forum, and the best I could come up with was for AT and I have a 6MT.
How do I take it apart and if there are pictures along with explanation, that'd be awesome!
Old 02-18-2009, 08:32 AM
Detail Cars in Philly in
dmassott's Avatar
not certain, but pretty sure its the same procedure, with prying up from around the ebrake and going from there
Old 02-18-2009, 09:51 AM
LukeaTron's Avatar
It's exactly the same as the AT. If you want to get the plastic piece all the way off you'll have to take off the shift knob and the locking nut from the shifter shaft. The boot then just slides right off.
Old 02-18-2009, 10:09 AM
Mike D from Ohio
miked8887's Avatar
Hopefully this helps you out:
http://rides.webshots.com/album/482100858sQavkT
Old 02-18-2009, 11:05 AM
Jdm.CL7's Avatar
It's pretty simple, you just gotta be careful with those clips. And if this is your first time taking off the center console, you may have to you a bit more force almost as if you're about to break it.
Old 02-18-2009, 11:50 AM
PACman's Avatar
Very true. My first time, I was yanking the console while on my knees on the passenger seat.
Old 02-18-2009, 12:05 PM
wooh, I guess that explains why I couldn't get it off. I was just applying somewhat half of the force afraid that I will break the clips
I will try that then...
so... do you start from the front or from the e-brake?
Old 02-18-2009, 12:17 PM
PACman's Avatar
I did e-brake location first. Use the rubber side (handle) of what ever tool you have so as not to scratch the plastic, to pop the back clip up. I could not get any grip doing the front part (not an ashtray) first.
Old 02-18-2009, 01:01 PM
LukeaTron's Avatar
Pro tip: Put a thin layer of grease on the metal clips before you put it back together. Half the reason it's so hard to get out is because clips get a bunch of surface corrosion and then don't want to slide through the plastic retainer thingys. The part will still clip on just as firmly but when you need to take it off again it just takes some firm pressure and it pops right out far less violently.
Old 02-18-2009, 03:13 PM
CL9 ABP
lcrazyaznl's Avatar
I have a short youtube of me prying the car apart.
Center console vsa and hazard button http://www.youtube.com/watch?v=b0M0V...e=channel_page
Blindeye_03 (02-14-2014)
Old 02-18-2009, 07:30 PM
Finally! i managed to pull it off. Thought I broke all the clips, but all still attached! And pacman, I did need to knee on the seat to pull it out... And I did it on campus parking lot, attracted a lot of attention... especially with my tinted window... not a good idea at all.
Old 02-18-2009, 10:16 PM
LukeaTron's Avatar
"Don't taze me bro!"
Old 02-18-2009, 10:45 PM
CL9 ABP
lcrazyaznl's Avatar
Its okay i should take a picture of me and my car, cuz everytime i take it apart people ask me wth happen to it did you get into an accident.
no just fixing a fog light or something.
Old 02-24-2009, 08:09 PM
kvelez07's Avatar
lcrazyaznl....Great video on removing the console and cd pocket....i removed the cd pocket on my car because the bulb burnt out, but i cant seem to find the bulb at any auto parts store...does anyone know the part number?
Thanks in advance.
Old 02-24-2009, 10:23 PM
CL9 ABP
lcrazyaznl's Avatar
I recall its a small wedge bulb i replaced mine with a superbright led if i recall
74 type
wedge.
Old 02-25-2009, 08:58 AM
kvelez07's Avatar
74 type
wedge.
Thanks Dude.
Old 02-25-2009, 01:27 PM
Mike D from Ohio
miked8887's Avatar
I like these ones
edit: heres the link:
www.autolumination.com/74.htm
Old 03-02-2009, 08:04 AM
-Mike
yungwunn911's Avatar
hi all,
does anyone know if the plastic trim around the shift boot is replaceable??
I was taking out my center console and that trim broke off! =(
http://www.acuraautomotiveparts.org/...s=&view=normal
#5 is the entire center console panel, I just need that little semi rectangular trim that goes around the boot.
thanks
Old 03-19-2009, 03:57 PM
Mike D from Ohio
miked8887's Avatar
^^nobody seems to be answering you
I would imagine you have to buy the entire piece #5. Sometimes its hard to find a sub-piece without having to buy the whole piece.
On that link, #5 was $36 (if I remember). That doesn't sound too too expensive to fix a cracked interior piece. I could imagine the dealership would make you buy the whole piece too.
Old 04-15-2009, 12:16 PM
Jottle's Avatar
For some reason, I can't for the life of me get those last two clips (by the seat heater switches) out. I've pulled as hard as I can underneath the shifter trim part and from the "not an ashtray" bin, and those two clips are super solid in there. It's so frustrating as I've removed all the other clips around the center console. What am I doing wrong? I'm going to get a f***ing eye hemorrhage if I pull any harder. Those two metal clips aren't going anywhere! Any tips?
Old 04-15-2009, 03:46 PM
CL9 ABP
lcrazyaznl's Avatar
just take a flat head near the front to clips and slowly pry up towards it. Chances out their just stuck. I mean mine pops out so easy since i've done it so many times. The first time I did it was a slow pry between each set of clips.
Old 04-15-2009, 03:52 PM
Jottle's Avatar
I've tried a flat head under the shifter area. Do you mean pry with a flathead on the side that is attached to the "not an ashtray" pocket?
Old 04-15-2009, 04:22 PM
CL9 ABP
lcrazyaznl's Avatar
Yea pry around where the not an ashtry, cuz the two clips are hidding there.
Old 04-15-2009, 08:41 PM
Jottle's Avatar
Got em! Unfortunately, I totally scratched up my center console doing it. The flat head around the sides did the trick though. Thanks!
Old 04-16-2009, 09:48 AM
CL9 ABP
lcrazyaznl's Avatar
Yea i know what you mean the darn flat head stills scratched up my car with a towel in front of it.
Old 04-16-2009, 12:58 PM
aCUREa's Avatar
I got mine off yesterday for the first time too. I didn't scratch it, but one of the metal clips became mutilated. It still fits on sturdily though, as if it didn't happen. If you stick something underneath the panel to pry, be careful you don't hit the clips when you stick the prying tool in. that's how I mutilated mine. I'm lucky it still fits.
There are actually 8 clips that need removed: 2 front, 2 back, 2 on each side. Its best to start from the front and pry each clip one by one.
Edit: it took me a while to get it and was VERY frustrating.
Old 04-16-2009, 10:07 PM
Jottle's Avatar
Well I went and did the same stupid thing. Does anyone know if these parts are the same for 2005 and 2006? I checked the link above, and the 2005 #5 color is listed as "DV Dark M" But the 2006 part is listed as "Lead Gun M". They are different part numbers too, but I don't think any of these center console parts changed in the 2006 refresh. Can someone verify this for me? The 2005 part number is: 77294-SEC-A00ZA and the 2006 number is: 77294-SEC-A21ZA
Old 04-16-2009, 10:11 PM
Jottle's Avatar
You're lucky. The one thing I absolutely HATE about our cars is how easily that soft plastic scratched, especially if you have a lighter color interior. It's not a big issue on Ebony, but quartz shows EVERY single little scratch. And once it's scratched, it only looks worse if you try to minimize or cut at the scratch. I have yet to see anyone who has been able to buff out or use a heat gun to make the scratches match the exterior color of the plastic.
Old 04-20-2009, 06:15 PM
ROMA's Avatar
Tsx center console
Does anybody know if they make a dash kit for a 04 tsx and how to remove the cd console pics would be nice please or video
Old 04-21-2009, 07:36 PM
aCUREa's Avatar
Removing the cubby cd holder is cake. I pulled it out 70000 times. Sitting in the driver seat, grab the floor of the cd holder with your right hand, and grab the cd holder door with your left. Then pull it straight out. You'll need to exert more of the force on the bottom of the cd holder (right hand). Only exert a little bit of force on the door with your left hand so you don't break the door.
I'll post pics of how to grab it. The problem was that I couldn't take a pic of both of my hands on it at once since I needed to hold the camera. So I took a pic of each hand separately so you can see how I gripped it. But use both hands when you pull obviously:
right hand: stick finger under
...then grab it
left hand: grab door like this
Here it is... theres still a wire attaching it so don't pull too hard after its out:
edit: I'm not responsible if you break it... be careful
Old 04-21-2009, 08:12 PM
CL9 ABP
lcrazyaznl's Avatar
Opps my bad i forgot to include that.
You just need to pull carefully on the door.
I pull on the rubber matt and lower edge.
Old 04-22-2009, 06:56 PM
aCUREa's Avatar
I was bored today and thought that since many people have trouble, I’d take pictures of how I got the center panel up in case anyone still needs help (the piece with the seat heater switches). Some people can just pull the whole thing off in one motion because it is loose from prior removal. But most people haven’t taken it off yet, so its not loose, so you can’t just pull. You’ll need to pry each clip up one by one.
Since it is so hard to get off, I used a metal prying tool, which is frowned upon because of risk of scratching, but I never scratched mine yet with this tool. If you’re careful, the tool might only scratch underneath where you can’t see, but that’s it. BUT you have to be careful. If you’re worried, place a cloth between the tool and the points of contact.
Disclaimer: I’m not responsible for damage/injury. If you don’t like the metal prying tool, pursue a different method.
Here is the tool:
Start here and get the two clips up in the front by the ashtray:
^^getting the tool underneath is not straight-forward. You’ll have to use a separate plastic tool to help pull the panel up a little so you can fit the prying tool under. I didn’t show that here, but you can figure it out. ALSO, be careful that the prying tool, when stuck under, doesn’t damage something underneath. So you should stick the tool as close as the clip as possible. If anything obstructs the tool from getting under, don’t force it, but rather move the tool over to a spot where there is no obstruction.
Next, pry up the clips on the sides (4 total, so 4 separate pryings):
^^Again, there are some points along the side where plastic blocks you from inserting the tool, so pull the panel up a little and look to see where. You’ll most likely have to also stick your hand underneath and push up while prying the sides, like this:
Next (and last), get the two back clips up by the e-brake:
Stick the tool in like this first:
...then tilt it upward to get the prying tip under and pull:
...do the same exact thing to the other back clip here:
Below is it disconnected. You still have to unplug the heater switches, so don’t pull too hard until you do:
I also post 2 pics below of the back of the panel after disconnection. Notice where the 8 clips are:
Note: I didn't show any pics of me pulling. I just showed me placing the tool underneath. You'll have to pull pretty hard with the prying tool, but be careful, and if you sense something might break, then stop pulling and reposition the tool.
Last edited by aCUREa; 04-22-2009 at 07:00 PM. Reason: needed to add final note on bottom
Old 04-23-2009, 01:10 AM
CL9 ABP
lcrazyaznl's Avatar
Nice write up man!
Old 05-18-2009, 05:26 PM
3rd Gear
dropmmm's Avatar
nylon pry tools
Spend the 5 bucks get these:
http://www.harborfreight.com/cpi/cta...emnumber=95214
Old 06-29-2009, 06:43 PM
5th Gear
petegk's Avatar
This was a VERY helpful thread. After a lot of effort, I was able to get it all apart, thanks!
I now need to go and apply bandaids to my cut up fingers, LOL
Old 01-15-2010, 07:28 PM
justabox's Avatar
Sorry for bumping this old thread but I wanted to jump in and just thank everyone for their pictures and advice that helped me fix a problem I've had since March 09. I was rearended at 50 mph while waiting at a red light and after $10,000 in repairs, I noticed that the my center console CD holder didn't shut anymore. I weakly remembered that right after the accident I had tried to shut it while filling out the police report but in all the excitement forgot about it. I figured the accident was violent enough that something had broken inside the console that causes it to lock shut. I took it to an Acura dealer to find out about a replacement but didn't have the money and just decided to live with it. Everytime I would look at it, constantly hanging open, contents spilling out whenever I'd accelerate I would become annoyed all over again. Here at work I had some free time to kill and was browsing different iPod intigration kits and someone mentioned taking out the center console and I was reinvested. I would go home and get my toolkit and I would fix the damn thing myself! Just needed a guide to start me out and this was the first thread that popped up in my search. I immediately ran out into the parking lot of my work to see if the solution really was that easy. Boy, do I feel dumb that I've lived with it this long! And after about a minute of looking at how the little mechanism works, got it back in the proper position, replaced the console and am so stupidly excited about it that I came running right back here to thank you guys! Sorry about this content-less, stream of consciousness gushing but this has made me so happy. Thanks again, and drive safe everyone!
Old 06-16-2010, 11:12 PM
Jottle's Avatar
Anyone know if it's possible to remove the black storage box inside the center console? I'm talking about removing the box that holds the mp3 jack and the aux power in the 06+ models. I have the helms manual, but it doesn't show how to remove the box inside the center console. I've tried to do it myself, but I don't see a way to do it. Maybe I have to take the entire console out of the car first. Any advice?
Old 06-17-2010, 03:03 PM
aCUREa's Avatar
It looks like a lot of stuff needs taken apart for that. Mine was loose once so my whole armrest part wiggled, and I tightened the bolts on the back when you open it. Maybe start there.
Old 06-17-2010, 04:30 PM
Jottle's Avatar
I took out all the screws that hold the entire console to the car, and I removed all the screws in the console box, but the box seems to be almost pressure fit in there with no way to remove it. short of cutting open the console.
Old 04-19-2017, 01:06 AM
4th Gear
1kevin1's Avatar
thanks for this post!
SidhuSaaB
05-30-2020 12:40 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
g1underground
Mid-Atlantic
09-23-2015 01:18 AM
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
Quick Reply: How to remove center console
