Highest Mileage 1G TSX
Old 03-15-2013, 02:37 PM
  #81
joekam's Avatar
I should add that a good chunk of my miles are highway miles.
Old 03-18-2013, 12:45 PM
  #82
CL9 ABP
lcrazyaznl's Avatar
I will end my 2005 tsx auto streak at
214,000 miles
Nyc took a lot on the suspension
tie rods and control arms
Replace the transmission 3 times it failed at 125,000 due to a clog in the filters and did a drop in with another tranny with 66k miles and failed after I added another 60k.
This past transmission was rebuilt not by acura, and it only last 20k miles.
sad to see it go, but it had a good run!
It be getting rebuilt by a local performance shop. They were looking to buy the body and rebuild it up.
Old 03-18-2013, 10:19 PM
  #83
Miamicarfan's Avatar
214,000 miles
lcrazyaznl:
two questions:
1) what clog in which filter caused the first transmission failure? Does the transmission have a filter? To my knowledge, this transmission filter in NOT an item that is replaced according to the maintenance schedule.
2) when the first (and original) transmission failed, did car leave you stranded or where you able to limp back home or to repair shop? what did transmission do when it failed? any noises, grinding, inability to start from first gear or inability to shift to second, third, fourth, or fifth?
Thanks for any info.
Old 03-19-2013, 01:16 PM
  #84
CL9 ABP
lcrazyaznl's Avatar
Internal filters are not replacable , there is an small external filter that you can replace/ wash out every so often. I changed fluids at 40k miles. My car was also mainly all highway miles then to city miles in the later years.
I got slipping around 120k and brought it in one of the acura dealers didnt want to work on the car, so I went a local mechanic that i trusted. They outsourced the work to a shop that didnt do a good job and rebuilt it 2x and the third time they gave up. so my mechanic just told me to find a salvaged tranny and he will drop it in.
It slipped, and then started free spinning and i got stuck with a stalled tranny on the middle of the service road. A bunch of codes came on forgot them, vsa light and some warning lights too. I couldnt move the car no reverse or foward. The transmission did spaz out and lose tiptronic mode. (numbers dissappeared) It would work again when I shut down and waited a few seconds and restart. Seemed like something was over heating.
Old 03-24-2013, 01:32 PM
  #85
mmafighta's Avatar
Another member who has a 1st gen claims he has over 270K on an 05....An 05 man!!!!
Also, guy in the 2nd gen forum has over 100K already on his 10' TSX...
Old 03-26-2013, 10:27 PM
  #86
So, do you like...stuff?
RogerPodacter's Avatar
Yes I'll try to remember to snap a pic tomorrow. If I forget bump me a reminder. But I'll try to set an alarm for myself on lunch break...
Old 03-28-2013, 11:45 AM
  #87
I spend 2 much time here
jiggaman's Avatar
150K on my 04 TSX at the moment. repairs that i can remember below:
OEM part stuff
new rotors
brake pads
clutch
AC unit
Cat converter
Most of the other stuff i've had to replace has been aftermarket.
think its time for a new clutch again. This will be the second time i've had to replace clutch. car is running strong right now.
Old 03-28-2013, 12:46 PM
  #88
Surprisingly I'm on the same clutch over 300k on original clutch.
Old 03-28-2013, 01:11 PM
  #89
CarbonGray Earl's Avatar
My 05 AT Nav is at 130,000. I'm only going about 10-11,000 miles a year now since I work from home. Its still a great car to do my errands in.
Anyone think doing more mods are worth it at a high-mileage? Thinking about finally throwing pulleys on there.
Old 03-28-2013, 02:09 PM
  #90
jiggaman's Avatar
that's impressive. no clutch squeeking at all when taking off in first gear?
Old 03-28-2013, 05:19 PM
  #91
Roger:
Don't forget to post that picture of the odometer. And while you are at it, also post a picture of the exterior of your car. You are definitely the mileage king of these boards. Nobody has more than 300,000 miles on these boards let alone 400,000 miles.
Old 03-28-2013, 06:01 PM
  #92
CarbonGray Earl:
Didn't you at one time replace your automatic transmission because it failed on you? I believe you posted about that problem if I remember correctly.
I also have an automatic and wanted to ask what the symptoms were before it failed. Several questions:
1) When the transmission failed on you, did the car leave you stranded where your car had to be towed or were you able to limp back home?
2) Did the gears slip on you before tranny failed or no slippage before it failed?
3) Did you notice any type of noise on the car when the car was in park or neutral that sounded sort of like marbles in a tin can and then noise would go away when you put car in drive?
Old 03-29-2013, 10:52 AM
  #93
^^Ya, I did have it replaced a couple of years ago. To answer your questions:
1) I was able to limp home, but the tranny was working hard. The engine would rev very high before it 'caught'.
2) No unusual slippage before that happened, but I was always a little suspicious of tranny. My second tranny (a rebuilt one by my Acura dealer) is actually better.
3) I didn't hear any that, but it certainly wasn't reacting to my inputs the way I expected. It lagged when downshifting and shift roughly.
Good luck.
Old 04-01-2013, 12:38 PM
  #94
gardel's Avatar
Rogerrr...Pics....or it didn't happen!
Old 04-05-2013, 11:23 AM
  #95
mrgold35
mrgold35's Avatar
Received 1,508 Likes on 1,176 Posts
I just entered the 100,000 mile club today! Purchase new with 6 miles on the odo in May/06. I averaged about 14,285 miles per year in 7 years.
Old 04-05-2013, 11:42 AM
  #96
it's a car-drive it
nj2pa2nc's Avatar
Welcome to the 100k club
mrgold35 (04-08-2013)
Old 04-06-2013, 09:34 AM
  #97
[QUOTE=mrgold35;14410961]I just entered the 100,000 mile club today! Purchase new with 6 miles on the odo in May/06. I averaged about 14,285 miles per year in 7 years.
Size:  116.5 KB[/QUOTE
Congratulations mrgold35. We must have timed our entry into the 100,000 mile club. I just reached this milestone this past Wednesday April 3. I will post pictures soon. I am looking forward to the next 100,000 miles. It has been a fantastic car.
Old 04-08-2013, 12:21 PM
  #98
illinimatt81's Avatar
I rolled 100,000 last August and hit 109,000 last night.
Just had her in the dealer for an oil change over the weekend and they told me I have one of the best condition 2004's they have seen. Multiple service guys on different appointments have told me the car will run to 250,000+ the way I drive and take care of it. Never have had any major issues.
I keep the car in mint shape, polish/wax twice per year, do all maintenance. Still runs as good as day 1. Rock solid on the highway at 90 MPH.
I love this car as much today as I did over 9 years ago. No interest in a new car anytime soon.
Here's a video when I rolled 100K at 100 MPH. Won't say where!
nj2pa2nc (04-18-2013)
Old 04-08-2013, 01:05 PM
  #99
SeaJay's Avatar
I didn't know there was a 100k club :P
I'm at 116k on my 06 TSX.
No major repairs as of yet.
Things starting to consider for repairs...
Replace Rotors
Front Axels and Intermediate Shaft (I might have that Vibration issue).
Slave Cylinder.
I don't expect to need to start thinking to replace my clutch until the 150k mark.
Old 04-17-2013, 08:16 PM
  #100
6th Gear
GrayAcuraTSX's Avatar
05 TSX. 80k miles. routine oil changes and brakes.
Looking to get some slotted rotors and need to get my passenger door actuator fixed.
Old 04-17-2013, 11:24 PM
  #101
Need more room in
wong05tsx's Avatar
2005
178000 miles
nothing major really. just been following the maintanence schedule
Old 04-18-2013, 12:24 AM
  #102
Acura TSX 100,000 Miles 8/10/12 - YouTube
Congratulations and NICE music with that video. is that David Bowie's Major Tom?
Old 05-20-2013, 09:02 PM
  #103
aldohe's Avatar
https://acurazine.com/forums/album.p...ictureid=60094
Over 146,000 miles. Purchased this month from a girl who purchased from her mother in 2006 or 2009. Most of the miles were driving it back and forth from Dallas to Austin.
Old 05-31-2013, 07:51 PM
  #104
Mr. DB2's Avatar
My current (3rd TSX) has 183k and so far so good. Nothing more than routine maintainence.
Old 05-31-2013, 08:03 PM
  #105
gftgrill's Avatar
06 6mt TSX. 79k miles, I picked it up new with 22 miles on it (2 dealer transfer to get it here)
The only part that has failed outside of wear n tear is the coolant temp sensor that is in the radiator. $30-35 sensor + new coolant.
Old 05-31-2013, 08:04 PM
  #106
gftgrill's Avatar
Old 06-07-2013, 07:39 AM
  #107
aldohe's Avatar
Here's the pic of the odometer.
Old 06-07-2013, 09:16 AM
  #108
SeaJay's Avatar
I had to change this same sensor.
I bought my car still under warranty with 38k highway miles, and 2nd day I had it an 02 sensor failed. I don't know which one but I had in to the dealer the next day and had it fixed.
I'm now at 121k miles and no other sensor issues
Old 06-17-2013, 10:50 AM
  #109
Still Lovin my 06
bradykp's Avatar
Pulled into the driveway last night with 107,515 miles. Purchased on December, 19th 2005. Hoping to figure out a way to keep this car for as long as possible. But when the third kid comes, we're going to be challenged. Doing research now on fitting 3 car seats, if I can pull it off, would love to keep this car to 200,000 miles.
Old 06-19-2013, 09:35 PM
  #110
sameoldmacho's Avatar
Talking
167k, only major repair was the ECM which was covered cause of the RECALL...
Old 06-20-2013, 01:18 AM
  #111
jlukja's Avatar
04AT but just rolled over 70K mi. No major issues. Had the radio display go black last year at just over 60K miles. Took it to the dealer and they fixed it for me for $100 as a regular customer courtesy. Also had to replace the sun visor because it wouldn't stay up. Car is not a daily driver. Its now the wife's car, only used occasionally and on weekends.
Old 06-20-2013, 07:55 AM
  #112
mrgold35
mrgold35's Avatar
I just did the +100,000 service last week (spark plugs and adjust valves). I did not realize how much HP I was missing. My butt dyno feels the TSX power is up 5-8 hp (to factory 205 hp specs) and the combined mpgs are up by 1 mpg. 100,000 miles between spark plug changes seems a little long.
Old 06-20-2013, 11:55 PM
  #113
jlukja's Avatar
I changed my own at 45000. I could feel the difference afterward.
Old 01-30-2014, 12:31 AM
  #114
625k or Bust!
Clymerdude's Avatar
Hi guys,
Neebie to the forum. I actually found this site googling "high mileage tsx" and found this thread. I have an 05 tsx with 392,000 on it and shooting for 500k miles. was looking to see if anybody else had similar goals. im tracking my progress on my blog
http://tsxtravels.com/
i also have posted all my dealer only maintenance records all the way back to 25k miles. original engine, transmission, shocks, rotors, etc...
i'll have to replace the ac system this spring when it starts to heat up again though. other than that running strong!
Angelito (02-11-2014)
Old 02-02-2014, 08:31 AM
  #115
HokieAcura's Avatar
Clymerdude: I just read your blog, almost 400k is impressive and keeping all those service invoices is very impressive. I didn't read them all just 2010 where I saw one transmission fluid change, what is your tranny fluid change interval?
I have no doubt you will make 500k miles, it give me confidence in our 2010 TSX.
My comments:
-Exterior looks great for almost 400,000 miles, as does the leather
-Finding a dealer where you trust their service dept. is priceless
-I do my own oil changes for peace of mind and cost savings but your method has proven effective
-How is your wife liking the RDX? I've been eyeing that ever since the model change.
Clymerdude (02-08-2014)
Old 02-02-2014, 03:44 PM
  #116
4cruizn's Avatar
Originally Posted by Clymerdude
Hi guys,
Glad you found the Acurazine community, Josh! Onward to 500k
See you this summer!
Old 02-03-2014, 12:39 AM
  #117
Gallic Gun's Avatar
I'm still sitting just under 99k.
Old 02-08-2014, 05:02 PM
  #118
625k or Bust!
Clymerdude's Avatar
My comments:
Thanks Hokie
Not sure on the transmission fluid changes. Basically whenever the dealer said it was due I did it. Same with all the other service. The nice thing about the Boise area is that it's a big city, but little city feel. The guys at the dealership have been great these past 8 years. The car is always garaged, so that's been a huge deal in keeping it looking good. The princess is loving her new RDX. I originally thought she's put only 3k-4k a year on it. But we got it last Sept & she already has 3k on it. Give a girl a new RDX and she'll drive it as much as possible i guess. & yeas, she loves it. I drive it when we go out as a family and it is a very nice ride. No regrets here.
Old 02-10-2014, 07:41 PM
  #119
kamnewton's Avatar
new here! bought my families 04 TSX for a daily (im a subaru guy) we bought it BRAND NEW on 06-23-03, and still have it. purchased from arlington acura in the chicagoland area, the manager of the dealership informed us that we were only the second owners of a tsx in the entire state. no major repairs besides a rebuilt transmission, and its about to roll over 240k . Might be the highest mileage one-owner car here
Old 02-10-2014, 09:58 PM
  #120
625k or Bust!
Clymerdude's Avatar
Might be the highest mileage one-owner car here [/QUOTE]
Welcome to the site Kam. But sorry dude, I also bought my '05 tsx new and am currently at 393K miles.
tsxtravels.com
Quick Reply: Highest Mileage 1G TSX
