error code B0706
error code B0706
I am very occasionally (3 or 4 times) getting the Check Emissions System light. It usually goes off after a day or 2 and then may not show up again for weeks or months. A friend read the codes and I believe he said it was B0706 and related to the transmission. I've haven't noticed any performance issues. Anyone got a clue?
Code P0706 is a transmission range switch open circuit. It should not cause a performance problem but could leave you in a no-start condition as part of switch enables starter to turn over. If this occurs it may help to start in N position and move shift back/forth to reposition switches in console.
good luck
good luck
ran-d2007tsx (11-25-2017)
good luck
good luck
See attached.procedure. I have not done this job on a TSX but have on an V6 MDX. I had to access through the wheel well w/ tire and underbody shield removed. Procedure doesn't mention any access issues. I also had some challenges in removing the retaining nut on the switch pin.
Not a terrible job but some challenges. Probably not job to begin DIY experience.
It is possible that a wiring fault or connector fault could cause this code, but less likely than switch.
good luck
good luck
ran-d2007tsx (11-30-2017)
good luck
good luck
