engine light
Old 05-07-2015, 08:58 AM
4th Gear
tsxgurl04's Avatar
engine light
My battery was disconnected in my 2004 tsx when the battery was hooked back up my check engine light came on and stayed on...is this normal or should i bring the car to the dealer to get checked? Please help!!
Old 05-07-2015, 09:01 AM
Received 8,582 Likes on 6,629 Posts
If nothing has changed, removing the negative terminal again and then installing it can reset the light. If after driving a few miles and the light turns back on, there's something wrong in which you should use a OBD scanner to check the code.
Old 05-07-2015, 05:35 PM
4th Gear
tsxgurl04's Avatar
Thanks..the reading says its an vavle timing oil switch maybe Im missing word ...i think the code is 1580 and 1581...
Old 05-07-2015, 05:40 PM
4th Gear
tsxgurl04's Avatar
Sorry thats 15810...is this a part or a censor im really trying not to blow up on the repair guy but i really thing he is not being honest because im a woman...im just trying to educate myself...thanks
Old 05-12-2015, 07:20 PM
TexasHonda's Avatar
There is no code I could find resembling 15810. All engine codes are Pnnnn, where n is a number 0-9. If you can get correct code, write it down and post here for possible help.
If you're not happy w/ repairman's attitude, find another. Suggest checking w/ auto parts store and Angie's List.
good luck
Old 05-13-2015, 03:37 PM
4th Gear
Heavymental's Avatar
just get it cleared, if it comes on again then you have an issue.
MikeYutkin
09-10-2015 10:13 PM
Bahamanurse1
09-10-2015 10:05 PM
HeloDown
09-08-2015 06:51 PM
bryan zaragoza
09-08-2015 12:28 AM
whitesoxsfan12
09-07-2015 04:07 PM
Quick Reply: engine light
