AcuraZine - Acura Enthusiast Community (https://acurazine.com/forums/)
-   First Generation TSX Discussion (2004-2008) (https://acurazine.com/forums/first-generation-tsx-discussion-2004-2008-124/)
-   -   CheckEngine Light P0706 (https://acurazine.com/forums/first-generation-tsx-discussion-2004-2008-124/checkengine-light-p0706-969582/)
mars 05-04-2018 10:48 PM
Hi All,
I have a 2005 TSX with close to 240K Miles on it. No major issues so far.
I got check engine and light and with my OBD Scanner is showing the code P0706.
It looks like i need to replace the Transmission Range Sensor.
Any one has experience changing it and also what's the exact part number.
TexasHonda 05-09-2018 06:22 PM
1 Attachment(s)
I haven't done a TSX range switch but did on a MDX. Not too bad. Worked through the wheel weel w/ tire removed and jackstand support. Attached is procedure.
Part no is available on many web sites for Acura parts.
good luck
mars 06-01-2018 08:14 PM
Thanks a lot.
I replaced the part and had to manually reset the check engine light after replacing the switch.
It's much easier than i thought.
mars 05-23-2019 11:25 AM
I got the same Check Engine Light again.!!
Last time i got the part from autozone or advance auto parts.
Not sure why this part is failing so frequently. Planning to replace it again.
Reorge 05-23-2019 12:08 PM
Did you try to realign the sensor? If it's not aligned properly it will give you a code.
The part has slotted holes for alignment purposes.
Review steps 7 through 9 of the attached procedure earlier in this thread.
If part has failed:
OEM Item 20: https://www.acurapartsforless.com/v-...eft-side-cover
