Can Honda dealers code keys for our TSX?
I was going to get my key cut today at a local honda dealer because its the only one around. Can they code the TSX key? I called in and he told me its only $45 to cut the key from FLBUSA. He wasn't sure if he can do it and it'll be under my risk to attempt the coding/cut. Can it be done? Need an answer asap if possible, thanks!
I called my local Honda dealer and they said that they couldn't because the Acura Key Database and the Honda Key Database are two separate things and Honda dealerships do not have access to Acura Info. I think is was a cop out, but possibly true. My
wait..does anyone know if I need to bring in a key code. Or will my original key work be sufficient to program the immobilizer chip for the new tl key?
Preparation
To add a key with the HDS, you need these items:
^ Immobilizer Key blank (master), P/N 35113-SEC-A01 (Here is where you would have your TL Key)
or
^ Immobilizer Key blank (valet), P/N 35114-SEC-A01
^ One programmed ignition key (master or valet) for the vehicle
^ Vehicle's key code for cutting new ignition keys
^ Suitable code key cutter
^ HDS with 1.006.004 or later software
NOTE :Make sure the setup and time are correct before you use the HDS. Select the F12 key in the upper right corner to get the Set-up Details screen. Make sure Market: is set to USA. Select the time display in the lower right corner to get the Date/Time Properties pop-up window. Make sure the date and time are correct. For details, refer to the Honda Diagnostic System (HDS) Setup Instructions listed under Tool Information in ISIS.
^ 1st Password (Get this five-character code from the iN VIN Status Inquiry display. This code is changed yearly.)
Procedure
1. Use an appropriate key blank and a suitable code key cutter to cut a new ignition key (see S/B 99-010, Cutting keys With the Exacta Code key Cutter).
2. Connect the HDS to the 16P data link connector (DLC).
3. Insert a programmed ignition key into the ignition switch, and turn the switch to ON (II). Turn on the HDS.
4. At the screen prompts, enter the VIN and the odometer reading, and then verify the correct date and time.
5. From the System Selection Menu screen, select IMMOBI.
6. From the Mode Menu screen, select Immobilizer Setup.
7. From the Immobilizer Test Mode Menu screen, select Add and Delete Keys.
8. From the Add and Delete Keys screen, select Add 1 Key.
9. From the Add 1 Key screen, select Begin to add 1 key.
10. From the 1st Password screen, enter the 1st Password, and then follow the screen prompts. When you are finished, turn the ignition switch to LOCK (0), and then turn oft and disconnect the HDS.
or
Procedure
they wouldn't attempt to cut and code my key. they said they couldn't get an immobilizer code great....nearest acura dealer is 100 miles away.
thats what i figured. I told them i'd cut the key elsewhere provided that they can program the chip. They told me that they couldn't bring up the immobil chip info....arg...damn upstate...
You should call them up and ask if they have an HDS tablet with software version 1.006.004 or later. If they say yes, then call them a bunch of fkin idiots.
its great that I can find an expert on this stuff (moda) here online...damn moda why aren't you closer like....somewhere in ithaca!!! I'm gonna get my key cut at lowes i guess...i hope they don't mess up the key and ask them to attempt to try to program the key again.
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
