Notices
ACURA TSX ECU Help
Old 04-23-2019, 10:50 AM
New Member
ACURA TSX ECU Help
Hello,
I have a 05 TSX. I'm trying to replace the ECU. Will this require re-programming? Or is it just plug and play? I understand that it has an immobilizer. If it does need programming, what is the cheapest possible way to get this done? I'm trying to fix the car to sell. Any help would be great.
on another note, would a bad ecu cause the car not to go in gear? (Car was flooded to floorboard). Thanks Fam.
To Tho is offline
Old 04-23-2019, 10:54 AM
Received 13,979 Likes on 10,384 Posts
yeah, just sell the car broken.
you want to chase down the problems to a flooded car? tis gonna be expensive.
pull the whole interior out and look for water logged shit.
if the car starts, the ECU is working.
justnspace is offline
To Tho (04-23-2019)
Old 04-23-2019, 10:58 AM
New Member
thanks for a response. car was working fine prior to insurance company messing with it, even after the flood. (only thing was it didn't go into gear). If I can fix it cheaply then I will do it.
To Tho is offline
Old 04-23-2019, 11:00 AM
well it could be the ECU, it could be lots of things.
gotta go in there,tear every thing out and find the problem by troubleshooting..
could be a disconnected sensor
If I read that correctly, the insurance fucked with it and now it wont go into gear...(so, you're gonna be asking the insurance what they did to it)
To Tho (04-23-2019)
Old 04-23-2019, 11:03 AM
pull the ECU and look at the wire harness, check for corrosion.
if anything is corroded, clean it up or replace.
To Tho (04-23-2019)
New Member
All water was cleaned... trying to see what the options for programming the ecu.
To Tho is offline
Old 04-23-2019, 11:05 AM
if the car starts....ecu and immobilizor are working correctly.
any check engine lights>?
To Tho (04-23-2019)
Old 04-23-2019, 11:19 AM
New Member
car does not start now. I didn't know what the insurance company did to it. But all the warning lights from VSA, ABS, battery etc etc is on. When plugged into scan tool it pops up error linking to bad ecu. before going to the tow yard car was able to start but not able to get into gear. Thanks for all the responses.
To Tho is offline
Old 04-23-2019, 11:27 AM
ttribe's Avatar
Received 4,313 Likes on 2,359 Posts
MODERATOR NOTE: Thread moved to model specific forum.
ttribe is offline
Old 04-23-2019, 12:12 PM
Thank you for providing this info. your Original Post was not very clear.
buy new or used ecu. have acura or honda reprogram the immobilizer.
there is no way around that, unless you want to buy an HDS(honda diagnostic system) for this instance. which would be expensive for a one time thing. you can try an older HDS system found on ebay...but again, spending hundreds of dollars for a HDS for a one time deal isnt ideal
Old 04-23-2019, 12:31 PM
New Member
Would I require to take the car there or would I just provide a vin with the new/used ecu? for the HDS, I will look up info on this. Honda just quoted 165, but the service guy didn't know wtf he talking...
To Tho is offline
handsom-hustla
03-21-2016 06:50 PM
sr20bet
Second Generation TSX Discussion (2009-2014)
04-28-2014 12:10 AM
richardparker
Second Generation CL Discussion (2000-2003)
01-24-2009 06:24 PM
rice79burner
12-08-2008 09:52 PM
vaderx
First Generation CL Discussion (1997-1999)
12-24-2004 11:34 AM
Quick Reply: ACURA TSX ECU Help
