Notices
2007 TSX Key fobs not working
Old 04-21-2016, 11:54 AM
New Member
Hey everyone,
I just purchased a used 2007 TSX for my daughter, but neither one of the keyfobs will work to unlock/lock/panic button. The rear lights flash when I push the lock button though so the car is receiving the signal.
Should I try and re-program from what I have seen in other posts or is there something else I can try? I don't want to spend $130 on the diagnostics before trying to do a repair.
MimGrim is offline
Old 04-29-2016, 05:26 PM
Registered Member
Good luck. Now if I can only find my missing key and fob. I'm getting quotes for $200 for a key and programming. I'd give programming a try, what do you have to lose.
ran-d2007tsx is offline
Old 04-29-2016, 06:06 PM
New Member
Well after messing around with it some more, the trunk would open, and all but the driver door would lock using the keyfob. Had the driver door actuator replaced and everything works like a charm. Glad it wasn't something more serious.
MimGrim is offline
Old 11-08-2018, 06:46 PM
Registered Member
sounds like you might need to replace the battery?
ericwudi0830 is offline
Flipster23
Norcal
245
09-29-2017 09:45 PM
Quick Reply: 2007 TSX Key fobs not working
