2006 TSX - Questions about spare tire trunk tools
1 Attachment(s)
I just bought a used 2006 TSX, and two of the tools that are supposed to be in the foam tray on top of the spare tire in the trunk are missing.
From looking at pictures online, the two parts that are missing are what look like a screwdriver, and some sort of S-shaped part. 1) Is the screwdriver just a regular flat head screwdriver? What's special about it? Why is it in the foam tray? Is it needed to change out a flat tire? 2) What is that S-shaped part? Picture to show what I'm talking about.: Attachment 99461 |
1 Attachment(s)
Here's a better view of the S-shaped piece. It's at the bottom of the photo, circled in red:
Attachment 99460 "S-shaped" is kind of inaccurate, I know. Z-shaped? What is that thing? |
You don't need the screwdriver to replace the tire (I've done it. There's no tricks, just 19mm lug nuts.)
A mini flat-head screwdriver would be useful for undoing plastic clips when you're replacing a brake light, etc. |
Originally Posted by dv-
(Post 16184610)
A mini flat-head screwdriver would be useful for undoing plastic clips when you're replacing a brake light, etc. What about the other piece? The S or Z shaped piece? What is that used for? Do I need it? |
Originally Posted by breadfish
(Post 16184896)
Ok. So that screwdriver isn't essential then. Any old flat head will do the job (undoing plastic clips), I assume.
I believe that's the sunroof manual closing tool.
the Z shaped bar is the sunroof crank, just in case the sunroof stops working
Oh. I must have been thinking of a different car then.
(Post 16185084)
however, since I read the owner's manual way back when, I know the Z crank is for the Sunroof |
Ah, ok.
Looking through the owner's manual, it talks about the moonroof wrench on page 327. Thanks guys. |
