2004 TSX Starting Problem
Old 10-05-2015, 10:53 AM
Eui
3rd Gear
Eui's Avatar
Hi,
I can't start engine !
Battery output is 12.4, looks fine.
Fuel Main Relay - I can hear fuel pump motor sound when I turn on key, looks fine.
When I turn key on, it's only click sound, no cranks and nothing happen.
I think I need to replace new starter.
Is there any other idea to cause this problem ?
Thanks so much in advance.
Eui
Old 10-05-2015, 12:39 PM
Someone stole "My Garage"
curls's Avatar
Try boosting battery - even though it reads 12.4V, there's probably very little cranking amps available.
The click sound in my past experiences (many, many of them) means the battery is so dead that it can't even turn the starter motor, let alone the flywheel. (starter motor solenoid engaging the starter with the flywheel, is what makes the click noise)
How old is the battery?
Eui (10-05-2015)
Old 10-05-2015, 01:37 PM
kbh
kbh's Avatar
Are your symptoms like this?
https://acurazine.com/forums/problem...roblem-917220/
Check your battery connections very carefully and clean all contact surfaces thoroughly before you start replacing parts.
Old 10-05-2015, 06:37 PM
Eui
3rd Gear
Eui's Avatar
Thumbs up
Battery is just one year old....
I tried jump start but it was same, just clicking.
Thanks anyway!
Old 10-05-2015, 06:38 PM
Eui
3rd Gear
Eui's Avatar
Yes, it's same symptoms.
Thanks.
Old 10-06-2015, 07:46 AM
curls's Avatar
If you can, try whacking the starter a bunch of times with a broom handle. It's behind the intake manifold on the front of the engine.
Then try cranking it again.
Old 10-08-2015, 07:32 AM
BROlando's Avatar
Received 1,188 Likes on 893 Posts
Is the car manual or automatic?
Checked for loose battery cables? You sure that you hooked the cables firmly enough when you tried to jump it?
And can you turn the crank pulley (CLOCKWISE ONLY!) with a wrench, by hand? Use a 19mm socket and a 1/2" ratchet.
Old 10-08-2015, 09:00 PM
kbh
kbh's Avatar
So did you actually remove both battery terminal connections and thoroughly clean the inside surfaces of each where they contact the battery posts?
Old 10-09-2015, 06:39 PM
5th Gear
6speedtsx's Avatar
That's a good point. I think all the signs lead to starter though.
docboy
4G TL Problems & Fixes
21
02-01-2016 07:50 PM
Dpak
10-03-2015 05:12 PM
Tsquare2
10-02-2015 10:02 PM
Gooner86
10-01-2015 07:30 AM
SinCityTLX
09-30-2015 12:03 PM
Quick Reply: 2004 TSX Starting Problem
