06 TSX - Rebuilt or New Starter?
I have a 06 Acura TSX near 220,000 km. The OEM starter does not work anymore.
I want to keep the car to at lest 300,000 km. It will cost me $350 for new starter vs. $250 for rebuilt starter. Which is the better option? |
Greatly depends on the brand. I'd trust a Denso rebuilt more than some lesser brand new starters.
I recommend Denso rebuilt from NAPA or if you can wait for shipping it's available at rockauto.com for about $100 less. |
I installed this one in my 2004 TSX 3 years ago, and it's still working fine. The starter replacement isn't that hard (about 1 hour), so I took a chance with this part since it was far less expensive than an OEM part. |
If you change it yourself, you might also consider the time it takes to remove/install a new one. I bought a Duralast alternator from Autozone when my OEM one went out at about 170K miles. Who the heck knows who makes their alternators. Could be China crap for all I know. However, an alternator takes <1hr. to change and it has a lifetime warranty so I figured why not. If it dies, I'll just take it back and get a new one. I believe starters typically have a lifetime warranty from auto parts stores. Not sure about Rockauto though....
I owned an '07 TSX but never had to change the starter, so I don't know how involved it is. If it's a royal PITA, I'd go with Reorge's suggestion of Denso reman. Although for only $100, you might even consider new. Usually there's a wider gap than that. For the TL, reman's go for $180 - $250 while new (from the dealer) is about $600. That made the decision easier..... |
Originally Posted by dainfamous41
(Post 16450089)
In my 2004, it just started cranking slower and slower, like the battery was failing. I replaced the battery and it still cranked slowly. It finally just stopped cranking at all. I fiddled around with it (key on/off a few times) and it finally started, and I replaced it shortly after that.
I'm sure it was just the brushes were worn on the original starter, but since the rebuilt starter I used off Amazon was so cheap, I didn't bother trying to rebuild the original starter. |
The Intake manifold has to be pulled for easier removal. Keep this in mind when selecting which starter you want. I bought a new Remy for $159 off Rock auto..https://www.rockauto.com/starter
