04-07 ABS/VSA modulators should be recalled- complain to the NHTSA
410,000 Odyssey's and Element's are being recalled because the brakes fail because the VSA/ABS modulators leak air into the system.
http://www.google.com/hostednews/ap/...xFiRwD9EFSEIG3
Acura/Honda has been aware of the exact same problem with the RL, TL and TSX for 2.5 years and all they've done is issue a TSB for our cars. Look at the date on the TSB.
http://www.in.honda.com/Rjanisis/pubs/SB/B07-041.PDF
Modding newbie
If you haven't noticed this before reading the TSB, then you don't have the problem. Really, just because there's a TSB doesn't mean there's any need for a recall, or that your vehicle has the problem. TSB's don't tell people that there is a problem with their vehicle, they tell the mechanics that an issue has surfaced more than once and this procedure has been the cause in most of those instances.
SUPRMN84
10-07-2015 09:46 PM
HeloDown
09-08-2015 06:51 PM
