Thermostat location
Old 11-16-2009, 10:07 PM
1997 3.2TL
r.soodeen's Avatar
Thermostat location
Hi can anyone tell me where my thermostat is located and how difficult it is to change it, I think its working but i would like to take a look at it cuz Im about to change my coolant this weekend. Ive searched but havent seen a diy on how to change a thermostat. Let me know if there is a thread on here on how to do it, thanks guys.
Old 11-16-2009, 10:34 PM
'13 Hyundai Sonata
TLin401's Avatar
I took this image from another thread. (Sorry for the big pic)
I believe it is in the bottom left of the pic where the radiator hose goes into the engine.
Old 11-17-2009, 12:58 PM
大日本帝国
Go90go's Avatar
The lower radiator hose goes right into the thermostat housing. You can access it from there.
~Cheers~
Old 11-17-2009, 11:19 PM
1997 3.2TL
r.soodeen's Avatar
thanks tlin401 but i have a 3.2 and i think thats the 2.5 engine right? so mine should be in a different place. Hey go90go u said its on the lower radiator hose, is it difficult to replace?
Old 11-18-2009, 02:03 AM
大日本帝国
Go90go's Avatar
Not really, just have new coolant ready and bleed the system before driving it.
Once you take off the lower radiator hose, there are a couple bolts and that's it.
~Cheers~
Old 11-18-2009, 09:22 AM
1997 3.2TL
r.soodeen's Avatar
Thanks go90go I am going to change it this weekend depending on the weather, let u know how it goes.
Old 11-18-2009, 12:29 PM
大日本帝国
Go90go's Avatar
I'd get a 180* one. I currently have a 170* myself. Stock is 190*, IIRC.
~Cheers~
Old 07-06-2010, 11:00 PM
7th Gear
Mr Sand TL's Avatar
Unhappy
~Cheers~
I'm assuming you're going in from underneath the car right? from the top there is noooo room, the throttle cable is right in the way
Old 07-07-2010, 01:42 AM
desired_speeds's Avatar
It's the housing where the lower radiator hose clamps onto the engine block. you don't need to take off the radiator hose. just unbolt the 10mm bolts and you're good to go.
vpasla1
09-17-2016 07:24 PM
MetalGearTypeS
08-29-2016 08:28 PM
08_UA7_Gr33k
02-11-2016 02:17 PM
malvothegreat
2G CL Problems & Fixes
09-29-2015 08:00 AM
Quick Reply: Thermostat location
