starts but won't run unless key held on.
I have a 96TL 3.2 that ran great until 1 Hr. ago. When key is turned on, the dash is blank and nothing works. When key turned to start,dash lights up, everything works, engine starts and runs until the key is released. If you hold the key on just enough that the starter is not engaged, the car runs just fine. Any suggestions?
Could be a faulty ignition switch or wiring but personally I don't have any experience, but try googling 'car only starts hold the key' (or variants of that). I'm sure you're not the only one to experience that kind of problem. (Edit: does the car make any unusual noise when you try to start it?)
mada51589
05-03-2022 08:54 PM
asahrts
09-04-2015 05:55 PM
