Power Windows in-op, Gear stuck in Park, Panel gauges out
Hello folks, I'm new and was hoping someone familiar with the 1996 TL could help me out here. I had my wife's car detailed and after which her windows and sunroof did not work, the gear shift locked in park......we have to stick the key in the gear shaft to unlock and switch gear to drive, and also the guages on the instument panel do not move......any idea what this could be a result of???? Thanks for your help in advance.
Khmer Pride
windows-check your fuse inside the car or in your engine bay
stuck in park- sounds like break switch , press your break see if it clicks if it doesnt you need a break switch
gauge- speed odometer,rpm? which doesnt work? might be speed sensor or you might have to get a used odometer closed to your miles
GL and Welcome to AZ
Well, for the gauges none of em work anymore, seems maybe one thing that made all of these things stop working. Thanks for that, I'll keep it in mind but i'm thinkin some one thing is the cause of all these things going at once
First off, check all your fuses. All these may be tied into the same fuse. they may be different fuses. so check all of them. if there all good then youll need to check your wiring before throwing parts at it. it may be a shorted wire, not a bad part.
k6biv
09-10-2015 06:37 PM
