New to the forums and need help with iacv.
Old 01-17-2013, 10:06 PM
smokey__'s Avatar
Hello , im new to the forums . I own a 96 2.5 tl . When i cold start it , the RPMs are jumpy so the car basically revs its self repeatedly in park/neutral. And in drive/reverse the car gets jumpy at low speed . I suspect its the IACV ! Can someone confirm this and maybe link me to a " how-to " inorder to clean it.
Old 01-17-2013, 11:02 PM
main70072's Avatar
You can find many DIY on cleaning IACV just by googling. The only difference is to locate it on your car. Welcome!
Old 01-21-2013, 08:55 AM
98 3.2 Flamenco Black
Mandy's Avatar
Do you have a CEL on? Or else take it to a BM Auto store and have it checked for CEL's. Report back to us. Good luck.
Old 01-22-2013, 01:20 PM
smokey__'s Avatar
What exactly is a CEL ? Im not too familiar with abbreviations .
Old 01-22-2013, 01:25 PM
meazz1's Avatar
CEL = Check Engine Light
You will see the "engine" like yellow light that comes on in the dashboard telling you there is a problem.
Usually this comes on when there is an emission related issue.
Is it on?
main70072's Avatar
Check Engine Light
Old 01-22-2013, 01:46 PM
smokey__'s Avatar
Originally Posted by main70072
Check Engine Light
Oh ! I dont know it as CEL . But no its not on , i used the obd scanner and it has no codes what so ever. I also cleaned the iacv with no avail !
Old 01-22-2013, 01:47 PM
smokey__'s Avatar
Is it on?
Ohh. I know the light i just never referred to it as CEL . But nope it's not on !
Old 01-22-2013, 06:15 PM
smokey__'s Avatar
Help ? Anyone ?
Old 01-22-2013, 07:35 PM
main70072's Avatar
Did you pull the electrical connector off the IACV and spray both sides with cleaner? Wait for it to completely dry, plug back in, and reset the ECU.
smokey__ (01-22-2013)
Old 01-22-2013, 08:08 PM
smokey__'s Avatar
Yes i Sprayed the connectors , but I've never reset the ecu how do i go about that ?
Old 01-22-2013, 10:46 PM
main70072's Avatar
Disconnect your battery, preferably the negative terminal, for a few minutes then reconnect.
Old 01-26-2013, 04:12 PM
smokey__'s Avatar
Just as an update, the problem with the iacv has been solved. I unmounted the iacv again and cleaned it once again. Mounted it back up and ran 1/2 a can of seafoam through the pcv hose I believe . I took the car on the highway for about 10 miles. And the rough idle and jumpy rpm ceased.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
kev87a
09-26-2015 02:30 PM
blackwarrior
09-26-2015 09:09 AM
Quick Reply: New to the forums and need help with iacv.
