Helpppp, I Got Check Engine Light Code P1318 And Tcs Light At Same Time
Old 03-07-2007, 01:01 AM
luigiacura's Avatar
I Change Ignition Modules, Nothing, Car Is Not Failing, Just The Lights, Check Engine And Tcs Appear At The Same Tiime
Old 03-07-2007, 02:11 PM
bat-on's Avatar
Thumbs up
Could be emissions problem. If your millage is under 150k (or 14 yrs, which yours is) you qualify for a free service at the Acura dealer where they fix ur emissions issues, free plugs, coils (3.2TL) oil change, and other emission issues. Check out the link as well. Call the Acura phone# in the link and verify. Then call your dealer and request the service. Good Luck
http://www.nsxprime.com/FAQ/Reference/tsb/98-031.htm
Old 03-07-2007, 07:01 PM
98 3.2 Flamenco Black
Mandy's Avatar
Could be the Catalytic Converter....will this be covered by Warranty, too?
Old 03-08-2007, 01:24 AM
luigiacura's Avatar
thanks, I will go to dealer
thanks, I will let you know what happened
Old 03-08-2007, 04:16 PM
bat-on's Avatar
Catalytic Converter is definitely covered by the extended warranty. 3.2TL has a 3-way Catalytic Converter. They hook the car into the OBD port and run diagnostics. If no codes come up they determine the Catalytic Converter to be working fine. I have an OBD-II hand held device cost around 3 grand min. I can even reprogram my car computer for more power by changing different parameters. Not something u wanna mess around with if u don't know what ur doing.
Old 04-18-2015, 03:37 AM
acurarl99's Avatar
Same problem with Luigiacura P1318 lights on check engine replaced module and sparkplugs valve cover gasket...with no luck..still on. Can any one help me Pleassss
mada51589
05-03-2022 08:54 PM
Bahamanurse1
09-10-2015 10:05 PM
elietania
4G TL Problems & Fixes
09-05-2015 06:52 AM
pesobreeze
1G RL (1996-2004)
09-03-2015 12:26 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
Quick Reply: Helpppp, I Got Check Engine Light Code P1318 And Tcs Light At Same Time
