fuel gauge stays at the current level forever
1997 3.2TL
After I have the radiator/compressor fan motors replaced, the fuel gauge will not go back to zero after turning off the engine/electricity. Some of the relays for the fan motors were tested at the time of the motor replacement. It stays at the current fuel tank level forever after turning off the ignition although it is the correct level. Any idea about the fix? Thanks in advance
i have the same problem! eversince i but on that indaglo gauge my fual reads 3/4 full and never move from there, thinking about replacing the fual gauge but im afraid that it wont sove the problem. and theres no refund on that gauge.. any help with that..
By the way, I am pretty sure that the fuel gauge went to zero when eletricity was turned off before. The stated problem happened after the fan motors repalcement but that should not be related the the gauge. The gauge tells you the correct level of fuel in the tank and the fuel empty warning light also works regardless of the power on or off
when i turn off my car the fuel gage stays where ever it is. i think thats normal not to drop to E.
by the way, my gas light never comes on even when i'm on E. does that happen to anyone else?
'97 2.5TL Premium
my fuel guage doesn't drop when the car is off. It stays at the current level.
The E light is dim at first when almost empty and gets brighter. It should work. It should light up when you are down to 2 gallons or so.
mine use to go to e whan car is turn off. now it just stay in one spot no matter what! whats up with that i think im just going to buy a new gauge to see if tha gauge is missed up
TL no more!
Ok...I just consulted my Acura's service manual. Here's what it says:
Source: Acura Service Manual CD-ROM. '95-'98 2.5/3.2TL Page: 23-121
So...like I said before, the gauge needle will stay whereever it is even when the ignition switch is off.
Case closed!!
NOTE: The fuel gauge is a bobbin (cross-coil) type, hence the fuel level is continuously indicated even when the ignition switch is OFF, and the pointer moves more slowly than that of a bimetal type.
Case closed!!
Case closed!!
Case closed!!
TL no more!
You've mentioned about installing indiglo gauges. Maybe the needle is stuck onto the board. Try lift the needle up just a tad bit and see if there're any differences.
yea i have done that too its funny becouse if i move the needle it would slowly move back and just stay there. i dont know its werd i think im going just take the whole thing apart and play with it again.
TL no more!
The reason being is because many Honda vehicles with anything more than 4 cylinders have gas gauge needle drops to empty whenever you turn the car off. Our '98 Accord EX-V6 and our '05 Odyssey have gas gauge needles drops to empty whenever you turn the car off.
no. ur guys ur not understainding me, that cool. let me asplain. my needle dont move at all no matter how much gas i use. see my gauge reads three quaters full all the time i could be on a half or on e and the needle still says three quaters full it does not move from there. the needle should move closer to e as i drive and weast gas but it dont thats what im saying, i dont care what happens after i turn off my car. i hope ur guys can understaind me and maybe help me out, thanx for ur guys help..
TL no more!
Haha...I understand, you, bud. That's why I asked you if you had lifted the needle up just a tad bit. But now, I think your gauge is malfunctioning. Let me do some reading on the service manual and I'll post if I find something.
Received 2,328 Likes
Umm... every Honda I've ever been in, the gas needle goes to E when its turned off
TL no more!
Haha...not every. Your '97 TL's gas needle doesn't drop to empty when the ignition is turned off as confirmed by the service manual. Our '98 Accord's manual stated that the gas needle on the 4-cylinder models will stay at its current level even when the ignition is switched off while the V6 models' needle will drop to empty. They may have switched it around over the years but this is as far as I know. So that is why I said "many" Hondas instead of every Hondas.
Hmm.. mine drops to empty. When I put it on II (the setting that activates everything except starting the car) the gauge will go back up.
Over the past 100,000 miles, I've noticed that the low fuel indication consistently comes on with just under 2 gallons of gas remaining. (I can tell because if I refill the tank at that point it always takes about 15 gallons.) However, the needle's location when the light comes on has shifted. It used to come on just below the 1/8th of a tank point. Now it comes on just above the "E". I think the accuracy of the needle has degraded and that there is actually more fuel left than it says.
Does anybody know how these sensor work? Are the needle and the low fuel indicator separate sensors? Have others noticed that the needle accuracy has degraded with time while the indicator light has remained relatively constant?
Now that I've typed this up, I think I'll post this as a separate posting - so don't bother responding here.
Strange... my car must be a fluke
mrkingstonvi
02-22-2016 01:53 PM
rockyboy
01-25-2016 06:00 PM
