egr valve location on 3.2?
Old 06-10-2006, 12:53 PM
copy252's Avatar
took the cover off... didnt see it.... am i that dumb??? help!
Old 06-10-2006, 04:10 PM
Khmer Pride
KrayzieDxC's Avatar
right on the left corner of your engine cover,just look where the vacaum hose going to u'll find it
Old 06-10-2006, 04:27 PM
copy252's Avatar
that helps but i really have no clue wtf it looks like, what to do with it, and im engine stupid! THANKS THO! HAHA!
Old 06-10-2006, 05:11 PM
Khmer Pride
KrayzieDxC's Avatar
here you go
Old 06-10-2006, 05:20 PM
copy252's Avatar
thanks man! how any good suggestions on cleaning the thing??? i know mines gotta look shitty in there... plus... i have no clue how to remove and i have no clue how or what to clean.... im stupid.... gotta learn sometime tho!
Old 06-10-2006, 06:16 PM
Khmer Pride
KrayzieDxC's Avatar
well i clean al the ports for where the EGr valve goin to engine. hmm theres a forum for it..well go to this link http://acura-legend.com/vbulletin/sh...php?t=68912..n i follow this DIY n it help me pretty much..i bought a new EGR valve. disconnected the negative battery first then unplug the egr plug n replace it n clean ever bit of the clogg.
Old 06-10-2006, 07:56 PM
copy252's Avatar
thanks man. this should help. im assuming im gonna do something wrong tho.
Old 06-11-2006, 09:21 AM
copy252's Avatar
went and tried step one this morning.... remove the hose..... NOPE! that little fuckers on GOOD!!! any special trick to diconnect it? all i tried to do is pull it and it seems glued on almost.... idk....
Old 06-11-2006, 09:50 AM
copy252's Avatar
also the bolts are like rusted to nuts!!!! seems like it just wont come off..... thats my luck!
Old 06-11-2006, 12:07 PM
Khmer Pride
KrayzieDxC's Avatar
go to autozone.. and buy one of those rust bolts stopper it will losen the bolts a bit let it sit then take them out.hope ur using a good wrench to take off the bolts ..wouldnt be good if u use a str8 line wrench it will ruden ur bolts
Old 06-11-2006, 07:10 PM
TexasHonda's Avatar
I've found a short wobbly extension works wonders to access the nuts using a 12-pt, 12mm socket.
EGR is usally fairly clean. It's the EGR manifold distribution that usually is blocked.
A shop manual is essential for performing this maintenance correctly.
good luck
Old 06-11-2006, 07:25 PM
copy252's Avatar
good luck
yeah i need a download of the shop manual. i got one someone sent me but it just tells basic stuff
Old 08-03-2006, 09:01 AM
bma4406's Avatar
COpy
Did you ever finish your cleaning?
What do you use to clean the carbon out?
Old 08-03-2006, 10:07 AM
copy252's Avatar
Originally Posted by bma4406
COpy
SEAFOAM!!! its like the best crap $8.00 will ever buy!!! just let your car suck up like a half a can. put the other in your oil or fuel. The best way to do it is to get a plastic cup (i used a dunkin dohnuts ice coffee cup washed out cause i had finished it driving in to my house right before seafoaming ) anyways, cut the cup so itll fill about half the seafoam. Grab a friend and tell them to get in the front seat. now while the car is good and hot and still running. grab the pcv valve hose and tell your friend to rev it to about 2 and dont let it go more or less than that. let the hose suck up the SF nice and slow. youll see LOTS OF SMOKE FROM THE EXHAUST. after sucking is done (haha!!!..... sorry.... ), cut the car off. let it sit about 10 minutes. start her up! DONT BE ALARMED if she sounds like crap and look like she breaking down cause your barely getting any acceleration and theres TONS of smoke coming out the ass end! its the seafoam doing its thing. take her for a nice ride giving it some gas every now and then. your check engine light may be on for a little while to. also they recomend getting your spark plugs changed when you do this. also an oil change wouldnt be a bad thing either. both not SUPER urgent but id do it for the hell of it. hope this helped. ima seafoam my ES300 soon. only thing is i dont want to because changing the three rear plugs is going to be A PAIN IN MY A@#!!! ill prolly just wait till i got some extra money and have it changed when i get the timing belt done (in 40,000 miles)
Old 08-03-2006, 01:50 PM
meazz1's Avatar
which end of PCV valve hose do you undo? PCV valve end or the engine end?
Old 08-03-2006, 02:07 PM
Khmer Pride
KrayzieDxC's Avatar
should be on the right side of the engine..its slanted a rubber house
Old 08-03-2006, 02:14 PM
copy252's Avatar
i just took the actual valve off and put it in that end
Old 08-06-2006, 09:42 AM
bma4406's Avatar
WIll this affect my new o2 sensor aft the cat?
Old 08-06-2006, 10:48 AM
Khmer Pride
KrayzieDxC's Avatar
no it wont..it will just clean the nasty carbon build up in ur engine
Old 08-07-2006, 06:04 PM
desired_speeds's Avatar
removal DIY: http://acura-legend.com/vbulletin/sh...ight=EGR+valve
Mike734
12-10-2021 01:25 PM
vpasla1
09-17-2016 07:24 PM
MetalGearTypeS
08-29-2016 08:28 PM
fifer16
1G RL (1996-2004)
10-05-2015 10:12 AM
shawnafoxx
1G RL (1996-2004)
09-28-2015 12:33 PM
Quick Reply: egr valve location on 3.2?
