crankshaft position sensor problem help!!!!
I have 96 acura TL, I just change out the spark plugs then 2 days later then
engine is stalling and can't rev over 3000 rpm the engine light is on, so i
took it to autozone to pull up the code. then it pull up 6 codes one of them
is po335 (crankshaft position sensor) so do i have to change out the sensor?
but its $350 for the sensor!!
sounds like its in limp mode to protect the engine- what brand spark plugs did you use?
Codes are CLUES not diagnosis
What are the other code numbers- we need all of them to help you
And you current miles on the car- any other work done besides the plugs?
cycdaniel
12-17-2019 10:58 AM
09-17-2015 09:01 PM
