Chrome shift.
The 96 2.5TL premium did not come with the woodgrain around the shift plate. Later years have them. All the 3.2TL premium came with them. We also do not have the woodgrain piece around the power window switches either. Ebay has them but cost is a little high. Junkyard is best.
Str8 Home built
yeah cuz i wanted to get the wood garin all over in my interior you know what i mean. but i may have to go on ebay or buy them new. no junkyard in the 805 has a TL and if the do there already gutted. i only found on TL here at the junkyard and that was it.
'13 Hyundai Sonata
There is a DIY on here somewhere about how to do this but basically this is what you need to do. First you need to but paint stripper so that the sticker will come off and reveal the chrome. Next you need to unscrew the shift knob and remove the plastic piece with the gears in it. Next you could either remove the shift plate or leave it on (I left mine on). Then you take the paint stripper and put it ALL over the plate. Now wait an hour or two andwipe away the stripper and if all of the sticker didnt come off then put stripper back on this until all of the sticker is gone. Then if you removed it then clean it out in the sink or if it is still in the car then wipe it down with a wet rag. Finally put everything back together. Good luck.
Diy:
Take coin tray out (Remove two screws)
Remove screws on each side of console (2 total) Near edge of seats.
Open arm rest (big section) remove cloth cover. (remove 2 screws)
6 screws total.
Pull up ebrake.
Take out console.
Unplug lighter, shift light bulb.
Black plastic ring just pops out around shifter.
********Plate doesn't come off********
Just spray paint stripper on plate. Just try not to be messy. No biggie
Wipe away paint.
Reinstall.
6 screws total.
Pull up ebrake.
Take out console.
Wipe away paint.
Reinstall.
KaMLuNg (06-06-2011)
Diy:
6 screws total.
Pull up ebrake.
Take out console.
Wipe away paint.
Reinstall.
6 screws total.
Pull up ebrake.
Take out console.
Wipe away paint.
Reinstall.
yea i just did it yesterday. easiest thing to do to enhance appearance. First use a flat head screwdriver to pop out the gear plate. Then spray the paint stripper on the plate wait about an hour for the chemicals to sink in and then use a paint scrapper to peel off the black sticker it comes off with ease and there you go a clean shiny chrome plate just polish and your set.
Default
Here's some pics. I actually started the DIY after I had already pulled it off, but I still included the pictures of how I did it.
Step 1: Unscrew the shift knob. Lefty loosey.
Step 2: Pull off the black gear plate with a small flat head screw driver. It's held in by 4 tabs, 2 on top and 2 on bottom.
Once it's up a little bit you can pull it off with your hand from either the bottom or top.
They're just little pop-in tabs so it's hard to break it. Here's a picture of where the tabs are.
It has the light and gear indicator screwed into it. You can leave it on.
Step 3: Take off the grayish plate. It's held on by two tabs on each side. I used two screwdrivers to do this. One popped out the tab on the back and held it out, while the other popped out the tab in front.
I scratched the plate up a bit doing this, but it's on the side and that's not visible when installed.
Step 5 (not pictured): Spray paint stripper on the plate. It says it's not safe for plastic but it worked just fine. I had to spray it on, wait 10 minutes, wipe it off, and do it again.
Here's the shifter with everything off.
Step 6 (not pictured): Press your chrome plate back on. It snaps in.
Step 7 (not pictured): Press the black gear plate back on. I spray painted mine black.
Step 8 (not pictured): Screw the shifter knob back on.
Step 9: Polish.
Step 10: Admire.
Step 9: Polish.
Step 10: Admire.
Default
Dunno, bought the car with it like that. My best guess is that the previous owner left the sunroof open on one of the 110+ degree days here and it melted. I took off the plastic piece and set it on newspaper outside when I sprayed the stripper on it.
'13 Hyundai Sonata
I picked up a new console at a salvage yard for like $35. It is a quick fix because there are 6 screws that hold the console in. It is very, very easy to replace.
'13 Hyundai Sonata
98 Blue 2.5 TL 200,050 mi
Did this today. Looks great. Thanks for the write up. As mentioned before, it is not necessary to remove the entire console. Just remove the bezel around the shift plate with a small flat head screwdriver.
Tip for removing the shift plate:
Use pliers. Place the bottom jaw of the pliers inside the groove where the shifter sits; position the upper jaw of the pliers on the side of the shift plate so the teeth help to grip the underside of it.
Now simply pry the plate off gently. Once you remove one side, the other just slides out. Much easier done, than typed :P
98 3.2 Flamenco Black
Received 2,328 Likes
'13 Hyundai Sonata
Try a salvage yard.
I picked my console up for $35.
