A/c not turning off! Climate control not working! Help please
Hi everyone ,
AS the title says, all of a sudden in my Gf's 96 TL, Climate control stopped working . Ac is constantly on and on the climate control screen numbers are all scrambled and looks liek screen in froze and all the switches are like disabled and not workign at all ! Ac is blowing on full blast and nothign is working at all ! sometime fan is going on on low speed then jumps back to full speed "No switches are working" Anyone knows what it could be? i am assuming i might only need to replace A/c Heater control unit i think its bad? or it coupld be something else? from what its acting up , I can feel that the switches are broken as the "temperature numurals" are scrambles and not showing any actual numbers on it Help please Thanks a lot |
I'd start by checking fuse.
Originally Posted by tmnhs81
(Post 10468165)
I think AC is ON because of a "safety standard"( If something happens to climate control, it will still work on defogger). If this is it then I am 75% sure you need new climate control unit.<---correct me If I am wrong pls.
^ yes you need a new climate control, there no fuse for the climate control
Originally Posted by KrayzieDxC
(Post 10468550)
Have you tried disconnecting it and connecting it back up?
Originally Posted by vas25tl
(Post 10470225)
Also, out car have a self diag mode for the climate control unit. Try searching that up and see if you can get to that mode on the car. |
Originally Posted by Billu99tl
(Post 10470202)
ok i found a good condition climate control ! is it Easy to replace?
I have one for $40
(Post 10468107)
Hi everyone ,
