Any Side Marker DIY around?
Old 02-09-2009, 05:18 PM
98 3.2 Flamenco Black
Mandy's Avatar
Side Markers...that's what we need....any takers for a DIY?
Old 02-09-2009, 05:27 PM
'13 Hyundai Sonata
TLin401's Avatar
I'm def down for this if someone made a DIY on this.
Old 02-09-2009, 07:24 PM
Mandy's Avatar
Ebay has plenty of side markers...it is a matter of wiring up from the signals on the front to the side marker on the fender....
Old 02-09-2009, 07:38 PM
'13 Hyundai Sonata
TLin401's Avatar
You would most likely need a bigger relay to do this since it would be more power that the relay has to put out.
Old 02-09-2009, 07:52 PM
Mandy's Avatar
Where's tmmhs...hello....time for a DIY..side markers baby!
Old 02-09-2009, 07:54 PM
'13 Hyundai Sonata
TLin401's Avatar
hahahaha yea he is going to school to become a mechanic and knows about wiring so he would def be able to help out with this. I think that he was talking about installing them in a couples of his posts in other threads.
Old 02-09-2009, 08:02 PM
Mandy's Avatar
You betcha! He the man! He likes electrical projects, too. Give him 12 volts and off he goes!
Mandy's Avatar
Tapping into the main power in the steering column, now that's balls!
Old 02-09-2009, 08:04 PM
'13 Hyundai Sonata
TLin401's Avatar
Old 02-09-2009, 11:45 PM
tmnhs81's Avatar
OK guys I am here. In process of buying a house. Will take a little more time then expected, kinda torn between which ones to pick (amber or smoked clear from BMW). I'll def take this project.
Old 02-09-2009, 11:49 PM
tmnhs81's Avatar
I was at work all day long, checked it right now. Will def do this.
Yes I was talking about and I am def gonna be a mechanic. Hold on it guys..
I need more than 12 because I am grown up adult...
and ...lol
Old 02-10-2009, 07:56 AM
Mandy's Avatar
I am so excited tmnhs81 will take this on. I have read from my hondasuv on this DIY that he had it connected where it flashes alternate with the front signals.
Let's go!
Old 02-10-2009, 10:14 AM
tmnhs81's Avatar
^ Link??
Old 02-10-2009, 10:46 AM
Mandy's Avatar
I will post what he has done on his CRV....
Old 02-10-2009, 11:06 AM
Mandy's Avatar
Taken from HONDASUV: sr-crv post
"i wired mine up to do everything. i figured if i went through that much trouble then i wanted to get my "moneys worth"...lol the sidemarker has 2 wires of course, 12v and ground. i ran the 12v to the 12v of the turn signal. then i wired the ground of the sidemarker to the 12v of the park light. yes you read it right. both wires run to both 12v wires. when each wire doesnt have 12v sent to them (whether its turning or running lights) they rest at ground. so when i use my turn signal, it has 12v from turn signal and ground from park light (resting at ground). then when i use my parklights i get 12v from parklights and ground from turn signal wire. but heres the cool trick, when my park lights are on and i use my signal, it alternates on and off the opposite from my turn signals. it has 12v from the parklight and when i turn the signal on it sends 12v to it to. it has 2 12v and no ground so it cuts off. ill have to get a video of it up for yall to see."
Old 02-10-2009, 11:12 AM
Mandy's Avatar
Here's the set, but I want clear lens...
Here's the V that he worked on:
Old 02-10-2009, 11:14 AM
Mandy's Avatar
So, between the two of you guys...I think we are on to something....can not wait....next thing check where we can get a group buy on side markers.....
Old 02-10-2009, 11:20 AM
Mandy's Avatar
So according to the DIY, no need for relays....tmnhs81...what say you????
Old 02-10-2009, 11:41 AM
tmnhs81's Avatar
Hmm.. thats a cool trick to do still work with your parking lights but works as turn signal too. awesome. Like I said before I'll def do it, but it will take some time. I am busy with some loan and stuff and I still have to order a set. You don't need a relay but you may want to replace fuse for parking lights and turn signals with a bigger one.
Old 02-10-2009, 11:43 AM
tmnhs81's Avatar
And thats a nice looking CR-V. Never thought you can do much about to that suv.
Old 02-10-2009, 11:48 AM
Mandy's Avatar
You have not seen nothing yet...nice looking V's in there...looking at some side markers on ebay, can't really tell what will and will not work.
I might have to visit a local BM store and check out side markers if they have them. We need the universal one, that comes with mount....
I am partial to clear lens and amber bulbs...will definitely work for you and me, with our Tl color, tmnhs81!!
Old 02-10-2009, 11:49 AM
Mandy's Avatar
Anybody who has a TL with side markers already, where do you recommend to install it, location I mean...
Old 02-10-2009, 12:13 PM
tmnhs81's Avatar
I think location for this is by side molding on fender (on top of side molding)
Old 02-10-2009, 12:15 PM
tmnhs81's Avatar
Like this....
Old 02-10-2009, 03:08 PM
Khmer Pride
KrayzieDxC's Avatar
check out colt45 side markers
Old 02-10-2009, 11:36 PM
Integra_drk's Avatar
this is easy, done it on my last 3 hondas, you just cut the fender with a dremel and tap into the turn signal wire...
Old 02-11-2009, 06:41 AM
Mandy's Avatar
How do you get access to the fender via the fender liner? And you just wired it in parallel with the turn signal? No relays or anything?
Finally where did you buy your markers?
Thanks.
Old 02-11-2009, 10:25 AM
tmnhs81's Avatar
^ EBAY is the only place to get them. Search for bmw side markers and pick whatever you like. Its simple task to do. Cutting a hole through fender is only hard part/time consuming.
Old 02-11-2009, 10:27 AM
Mandy's Avatar
I will check out the BMW's. I have seen S2000 side markers, but are replacements not whole assemblies.
Thanks.
Old 02-11-2009, 03:16 PM
94-97 accord jdm sidemarkers look similar to the tl ones as well, which is what i am going to use.
Old 02-11-2009, 04:31 PM
Khmer Pride
KrayzieDxC's Avatar
Thanks.
jdm side marker search ebay
Old 02-11-2009, 04:36 PM
Mandy's Avatar
I like the BMW smoked ones, nice for my Black TL!
Old 02-11-2009, 04:38 PM
Mandy's Avatar
The Civic EK ones have a clip and tab and is just slide in, lock in, done.
I have been looking at some side markers, can not figure out how thay are attached to the body.
Old 02-11-2009, 11:28 PM
desired_speeds's Avatar
Sabers share the same side markers as EK civics, prelude (not sure which ones), and Legend, and im sure a few more cars. So it shouldn't be hard sourcing down a set. I got a set of mint Legend ones off of ebay for $20 shipped.
Old 02-12-2009, 11:28 AM
Mandy's Avatar
I found this DIY from the web:
http://www.giuffre.com/personal/side...idemarkers.pdf
Let's do it!
Old 02-12-2009, 11:36 AM
Mandy's Avatar
I found a few clear Accord side markers, with clip and tab to hold them in place. I am ready to order a set, they are not bad in price, $15 shipped. I am just waiting on our master mechanic sensei tmnhs81 to kick us off....I will definitely write a nice DIY...after I am told how to do it....
Old 02-12-2009, 12:12 PM
tmnhs81's Avatar
^Its simple as you posted a link from hondasuv forum, all you have to do is find a proper location and "plug" them into side marker or turn signal and you are good to go.
Old 02-12-2009, 12:36 PM
meazz1's Avatar
do you have to tap into both wires of the turn signal or just the positive and ground the other one on the body some where?
Old 02-12-2009, 12:49 PM
tmnhs81's Avatar
Either way, it should work.
I think if you want it like its your side marker for most part and you want it to work as a flasher too (flasher+side marker both) you need two filament bulb and a different holder/connector with three wires 2 for power (1 for flasher and 1 for parking light) and 1 for ground. I am kinda confused right now.. Will get back to you guys with proper wiring instructions.
If you are using them just for flashers, you should just run wires and side splice/solder them into flasher connector in bumper.
Its a long post with alot of confusion, sorry.
Old 02-12-2009, 03:57 PM
Mandy's Avatar
I am definitely getting it now...everyday it is getting clearer...watch out DIY coming shortly. This would be an awesome and simple DIY.
Quick Reply: Any Side Marker DIY around?
