ABS Makes a buzzing sound
Hello everyone! I have a 1996 Acura TL 3.2 and am having trouble figuring out what is wrong with the ABS. When I turn on the car the ABS makes a buzzing sound, the buzzing turns off and the ABS light turns on. I tried checking what code would pop up by using a paper clip on the DLC, on 4 and 9 but the ABS light did not blink any code. I was wondering if anyone has had this buzzing problem and if anyone knows how to get the code without using an expensive scanner, hence the paper clip... Thank you everyone.
My car makes the same noise it stops after about 20 seconds then I take off. I reed somewhere it just some air in the line that's why the pump turns on. Their is a way to get the air out I saw it on acurazine I will post it when I find it.
rockyboy
12-06-2022 02:29 PM
mada51589
05-03-2022 08:54 PM
