97 TL 2.5 Idle Problem At Stops
Old 10-04-2012, 12:03 AM
winn808's Avatar
Recently I've been having idle problems in park or when I come to a stop. Idle will go from 0.5 to 1k rpm. Also been having a hard start in the mornings sometimes. I pulled the codes and it blew my mind when I found this.
p0118
p0113
p1508
p0328
p0103
p0333
p0700
p1792
p0453
One of the codes in there is for my transmission and the hard shifting its been having. Please disregard that.
Any help would be appreciated and thanks for the help in advanced.
Old 10-04-2012, 02:06 PM
winn808's Avatar
does nobody have a clue to what im talking about?
Old 10-04-2012, 09:03 PM
main70072's Avatar
Start by cleaning the IACV and resetting the ECU.
Old 10-05-2012, 01:42 AM
Str8 Home built
bigwerm187's Avatar
I had the same problem. But with out those codes tho lol... just had to adjust the idle on the throttle body lol and a bad pvc.... Little elbow looking thing in the middle of the valve cover lol
The following 2 users liked this post by bigwerm187:
Sterling (01-27-2013), winn808 (10-18-2012)
Old 10-12-2012, 10:26 AM
zypkode's Avatar
Where is the IACV located on the 96 TL 2.5 ? Do you have any Photos ?
Old 10-14-2012, 06:20 PM
winn808's Avatar
so i cleaned the iacv. and car seemed to idle better until recently.
all of a sudden im on the freeways and it seemed to be losing power and surging back and forth. i'm thinking it could be the MAF sensor. should i clean that as well?
and also how do you check the voltage for the maf. i got myself a new multimeter and dont know what the hell i'm doing LMAO..
Old 10-17-2012, 10:38 PM
winn808's Avatar
@zypkode heres what the iacv looks like. its the one with the teal sticker
Old 10-17-2012, 10:39 PM
winn808's Avatar
Somehow was looking at the other threads and came across the same problem as me with 2 of the same codes. i'm looking at the coolant temp sensor. not sure why it would be causing trans problems but its worth a shot.
Old 10-18-2012, 06:48 PM
winn808's Avatar
Update
Just changed the coolant temp sensor and still the same problem. This time its even worse. i'll post a video up so you guys can see it. Maybe yall know what it could be.
Old 10-18-2012, 07:03 PM
winn808's Avatar
Video
<object width="560" height="315"><param name="movie" value="http://www.youtube.com/v/2hZiRghp0RY?version=3&amp;hl=en_US&amp;rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/2hZiRghp0RY?version=3&amp;hl=en_US&amp;rel=0" type="application/x-shockwave-flash" width="560" height="315" allowscriptaccess="always" allowfullscreen="true"></embed></object>
winn808's Avatar
Old 10-18-2012, 08:35 PM
white2.5tl's Avatar
adjust the idle screw and maybe clean ur maf sensor
Old 10-19-2012, 08:01 PM
winn808's Avatar
thanks for the reply. but i did clean the maf sensor. i used carb cleaner and just sprayed inside where the wire sensor is, maybe i just didnt let it dry long enough. its worth another shot.
but in the meantime any other suggestions?
Old 10-19-2012, 11:40 PM
white2.5tl's Avatar
dont know about using carb cleaner but there is cleaner made specifically for use on maf sensor. i say adjust the air idle screw to see if it help
Old 11-03-2012, 12:38 AM
winn808's Avatar
so after about couple weeks of driving. I can say that it must have been fixed. I think the key was the engine coolant temp sensor replacement. although i would not know why it would make the idle bog
Old 01-08-2013, 03:21 PM
B A N N E D
lifted tl's Avatar
Try cleaning out your egr valve I had the same problem with mine
Old 01-08-2013, 06:06 PM
98 3.2 Flamenco Black
Mandy's Avatar
Ditto, this is a good start.
Old 05-25-2013, 03:53 PM
russell707's Avatar
Hey so its good now? Nomore dying?
Powder Monkey
2G CL Problems & Fixes
09-09-2018 12:55 AM
udelslayer
1G RDX Problems & Fixes
05-06-2016 12:27 PM
rklatzkin
09-23-2015 04:08 PM
Mike Bertram
09-10-2015 09:27 AM
NSolace
09-03-2015 08:14 PM
Quick Reply: 97 TL 2.5 Idle Problem At Stops
