96' 2.5TL Won't Start, sometimes...
My 96' 2.5TL starts and works fine but once in a while it won't start after I've gone somewhere. NOTHING. No crank, no noise whatsoever. I keep try every couple of minutes or so and then, all of a sudden, voila!, it starts. The wait time will vary from 1 to 30 minutes. I've sent it to the mechanic a couple of times but since the problem is sporadic, it has not happened to him. The key seems pretty worn (no sharp edges). Could this be the problem? Does a starter behave this way? Could it be something that stops working when it gets hot and works after cooling off a bit? I have no clue. Please HELP.
Str8 Home built
have u checked your termanals on your battery..? are they tite on there..? i had the same problem but i changed my termanls and i never had that problem again. the stock ones are garbage thats also why i changed them.
If you dont' get even a "click" from the starter when this occurs, the keyswitch is most likely. I think there was a recall on ignition keyswitch assy for many 2.5TL models. Check TSB's.
If it "clicks" then starter is most likely the problem.
Check battery cables for good, tight, and clean connections.
good luck
good luck
Thank you all for the replies.
No "click" or any noise from the starter when it doesn't start.
Battery terminals and battery seen OK.
Any idea where I can get the info on the problem (or recall) with the ignition keyswitch assembly? Where do I search for TSB's?
Thank you.
Thank you.
Is this common?
Any idea how much for the cylinder?
Can I get only from the Acura Dealer?
Does it come with a new set of keys?
Can the problem be solved with remote starting?
Thanks.
Thanks.
I have the same problem...what was the solution to your problem Rold_Man? Not sure if I made the problem worst but I do remember when the engine cools the car will turn over so I poured water on the engines block. Now car won't turn even though the engine is cool. Everything is fine: battery is OK, terminals OK, new starter was put in last week...what could be the problem. Electrical? Very frustated here and the car is in mint condition. Never in an accident and only 110K miles. I also just did a full engine job (seals etc) and major tune...Only problem, it does not turn over! Even the radio and all lights work perfectly...PLEASE HELP!!!!!!!!
'13 Hyundai Sonata
If you poured tons of water on the coils that go to the spark plugs and the things that they go to (I forgot the name) but that might be your answer.
Thanks guys for the replies...just spoke to my mechanic and he said that it could be something with the alarm..There was an after market that he removed. (frustrated!) I don't know, I also have problems with the key turning, it gets stuck!
I feel like taking a monster truck and going to town on this car...Never buy another old car again...specially this kind... Does anyone have a monster truck they can lend..it would be very therapeutic
Do you guys think its the cylinder? What can it be? I have bought to so many mechanics and the car is in really good shape...spend thousands getting it to this phase and don't want to let it go! PLEASE HELP or its the power washers
i had this problem a couple of months back. same situation as you. go somewhere, sometimes it start, sometime it don't. it seem to happen the most when the car gets hot or driven for a long time. i took it to my mechanic. i told him to check the starter. a few hours later, i get a call from him and he told me its my aftermarket alarm starter kill not sending power to the starter. so he just push in all the connection on the alarm brain and it been working good since.
he told me that the aftermarket alarm "starter kill" is malfunctioning. so the alarm is not sending the signal to the starter to let it start the car. he ask me if i want to take it off, i said no, and i went to pick up the car. i think he either push in the connector to the car or bypass the kill switch. that i dont now. i just havent had the time to check it out. but it has been working fine since then. sorry if it didnt help much.
Default
I have a similar problem but it doesn't seem to be as bad. I'll turn the key and it won't do anything. Then I'll stop, retry, still nothing. Usually by the third try it will start. It's never delayed me for more than 10 seconds.
I replaced the started about 3 weeks ago and ever since it happened only once. So I don't know what to make of this. I also have an after market remote door lock which has a starter kill relay.
I have this problem constantly and one day i was stranded at a gas station for 3 hours and after that the check engine light said that crank positioning sensor is givng no ssignal. the only way i seem to start the car today is by the remote starter that came with the car and that seems to work. But manuel starting the car from the key seems to be the problem for me sometimes or should say 90% of the time. The car does click when i do turn the keyover and try to start it. There is also times when the key or remote starter seems to never work. so idk.
That was a problem with me too last summer. But the stereo place that installed it said that it was the brain and they replaced. That warranty has good for over 5 years or more now lol. and the car has been fine ever since. But i dont think thats my problem now with the car. because i would turn the alarm off and it still wont start.
If there is no aftermarket alarm; the possibilities are; keyswitch assy, wiring (broken wire - less likely)
Note, some alarm systems don't interrupt starter signal but rather the ignition supply voltage. In this case, starter turns engine over, but engine won't start.
Above assumes you have checked and found no voltage at starter signal wire when keyswitch is turned to Start. You have checked that,...right?
good luck
After reading this thread the other night. Just trying to ingest more information, etc. My car failed to start. It does, however crank and stuff. Can't seem to hear my fuel pump pressure up the lines however. Bought myself a new fuel (main) relay. Putting it in tonight. "Crossing fingers" Please let it be my relay. Fuel pump would suck! Still thinking of purchasing another 1st Gen. So I can have 2. I would work on one, get it primo and then fix the other. Thanks to you all here at Acurazine, for your suggestions, assistance and the overall camaraderie (alt:comradery)!
大日本帝国
Acura won't start
Hi guys - I have just finished reading the thread since I now have similar issues with my Acura. I'm wondering if anybody found a solution. However, in the mean time, I am pursuing the main relay since my boss told me the same thing happend to his Acura and he soldered it and had no problems after. Here is a website I found to assess the soldering in the main relay and fix if it looks bad. http://bmmd.tripod.com/
About a month ago I noticed my car would have a fraction of a second delay starting after I turned the key. Finally the car would not start and I was sure the battery was not weak. I call AAA and they tried to jump start the car... no success. So I sent it to a mechanic and paid $275 to have a new starter put in. It worked great... for a few days and then failed to start with the same symptoms as before the repair. My boss then told me about his experience and success with the main relay and that is what I'm pursuing now.
Virtually everyone in this thread w/ a problem refuses to do any diagnostics. They want to know "what's wrong?".
It could be missing electrical start signal (keyswitch), missing fuel pump power (main fuel relay), bad ignitor/coil, oily distributor, etc. If you don't want to do diagnostics, your only option is to start replacing parts and hope to fix the problem before you run out of money.
good luck
good luck
I am still getting stranded now! Can Some please help me, or give me some sort of suggestion? This freaking car is making me mad! It uauLly happens After long drives, or fast drives. Some times the key won't start the car, the remote start does. The car does click with the turn of the key, just no crank. I know some else is having this problem, or had. I have a 3.2 tl. Oh yea, I do have an alarm,but the brain has been replaced before, so I don't think that's problem. Plus, I turned the alarm of and still no crank. o_O
So can you hear the fuel inside the fuel filter cycling is it constant not intermittent? I would almost bet money on the key ignition cyclinder though. Even the ignitor sounds suspect if you threw water underneath the hood. But if you got dianostics for the crank positioning sensor there's your problem there it does happen sorry but true.
It's not it. This thread is old. I did get a new sensor and still the same problem. I don't know what kind of click it is, but when I turn the key i hear a click just no crank. I Donny remember hearing any fuel. Is that same sound in the back of the car of fuel bubbling? If so, no I don't think I hear that. This time it happened, there was no other sound, but the clicking where the key is coming from.
sorry if im jacking the thread..and my car is a 2.5
大日本帝国
Most of the DEI stuff is good, I just prefer Clifford since I've had them since the wire for an antenna with a two button square remote days. Plus the recent/previous generation remotes look nicer, IMO.
~Cheers~
~Cheers~
This was my ignition switch DIY.
https://acurazine.com/forums/1g-tl-1996-1998-101/ignition-switch-install-write-up-pics-725339/
