2.5 TL Main relay location help please!
Old 10-25-2009, 03:38 PM
leventis72's Avatar
Just checked the repair manual and it shows it as being to the left of the instrument cluster pg 23-9 if anyone has the manual. Do I have to take out the cluster move it to the side to access it. Any help greatly appreciated.
Old 10-25-2009, 04:00 PM
'13 Hyundai Sonata
TLin401's Avatar
I looked at your other thread and from what TexasHonda said, I believe it is in the area of the fuse box. Stick your head where the pedals are, look to the left, and turn the knob on the panel door, and then the fuses will be exposed.
Going off of what he said they should be there.
tmnhs81's Avatar
I think its around left kick panel somewhere..
Old 10-26-2009, 10:03 AM
leventis72's Avatar
looked all over high and low not to be found its not under the hood like someone said took out instrument cluster out looked to the left nothing. iM LITERALLYgoing crazy looking for this fuckin thing
Old 10-26-2009, 10:14 AM
'13 Hyundai Sonata
TLin401's Avatar
Look on the passenger's side. There are a few relays up there when I looked for the fog light relay. It might be one of them.
Old 10-26-2009, 11:44 AM
TexasHonda's Avatar
I'm at office, but will try to post a pdf image when I'm home this evening.
I just noticed my MFR was "hanging out" just above the kick panel on driver's side yesterday and tucked it back behind panel. I did not rehang MFR on bracket as it's difficult to remove if you do. I suspect you're looking too low, it's pretty high up under the dash.
good luck
Old 10-26-2009, 07:43 PM
TexasHonda's Avatar
PM your email address and I'll forward a pdf diagram of MFR location. It may help.
good luck
Old 10-27-2009, 01:11 PM
leventis72's Avatar
thanks i found it
Old 03-08-2012, 03:50 PM
bigdrew88's Avatar
main relay location
my email address is mr_andrewlaw10@ahoo.com. I have taken down side(fuse), and other panels under steering wheel, but I don't see that relay anywhere. HELP PLEASE!!!!
Old 04-14-2012, 07:36 PM
3rd Gear
Deb Boggs's Avatar
good luck
Could I get the pdf of the diagram for the location of the relay? (deb.boggs713@gmail.com)
Old 04-15-2012, 02:42 PM
TexasHonda's Avatar
Sorry, I found that I don't have software to generate a pdf image from original manual. The picture shows a small box (2x1x2) just above the under dash fuse/relay panel on the driver's kickpanel.
good luck
Old 04-27-2017, 10:41 PM
5th Gear
Luttrj's Avatar
So you found it. Where?
08_UA7_Gr33k
02-11-2016 02:17 PM
swany0095
2G TSX Performance Parts & Modifications
10-07-2015 02:18 PM
Kres43
1G RDX (2007-2012)
10-03-2015 07:16 PM
greeneyes.hypnotize
09-27-2015 02:47 PM
johnpancakes014
09-27-2015 12:58 PM
Quick Reply: 2.5 TL Main relay location help please!
