2.5 TL Main relay location help please!
Just checked the repair manual and it shows it as being to the left of the instrument cluster pg 23-9 if anyone has the manual. Do I have to take out the cluster move it to the side to access it. Any help greatly appreciated.
'13 Hyundai Sonata
I looked at your other thread and from what TexasHonda said, I believe it is in the area of the fuse box. Stick your head where the pedals are, look to the left, and turn the knob on the panel door, and then the fuses will be exposed.
Going off of what he said they should be there.
looked all over high and low not to be found its not under the hood like someone said took out instrument cluster out looked to the left nothing. iM LITERALLYgoing crazy looking for this fuckin thing
I'm at office, but will try to post a pdf image when I'm home this evening.
I just noticed my MFR was "hanging out" just above the kick panel on driver's side yesterday and tucked it back behind panel. I did not rehang MFR on bracket as it's difficult to remove if you do. I suspect you're looking too low, it's pretty high up under the dash.
good luck
good luck
main relay location
my email address is mr_andrewlaw10@ahoo.com. I have taken down side(fuse), and other panels under steering wheel, but I don't see that relay anywhere. HELP PLEASE!!!!
Sorry, I found that I don't have software to generate a pdf image from original manual. The picture shows a small box (2x1x2) just above the under dash fuse/relay panel on the driver's kickpanel.
good luck
good luck
08_UA7_Gr33k
02-11-2016 02:17 PM
johnpancakes014
09-27-2015 12:58 PM
