1996 2.5 TL Water Pump
I was going to replace the timing belt on my 1996 acura tl 2.5, and I figured I should buy a kit and replace the water pump and tensioner too. What kit should I buy that is quality, but costs under $160ish
Only use a OEM part for the water pump. Even the good brand kits are known to have issues with them leaking or seizing.
Water Pump: $129 19200-P1R-003
https://www.acuraoemparts.com/oem-pa...dXRvbWF0aWM%3D
Water Pump Seal: $3 19222-PV0-300
Timing Belt: $45 14400-PV0-004
https://www.acuraoemparts.com/oem-pa...QtYXV0b21hdGlj
Belt Tensioner/ Adjuster: $68 14510-PV0-003
Use "acurazine" as a discount code and get 5% off your total.
imakeholesinu
12-30-2012 09:08 PM
DT0450
1G TL Problems & Fixes
11-28-2012 12:17 PM
