1997 Acura 3.2 TL Premium Crankshaft, A/C problems HELP!
Here is the 42 second video to my problem:
Sorry there is no audio but it seems that the bearing is broken because there is noise when activating the A/C.
It barely blows air or doesn't at all. When I click the A/C button the clutch does move but not without displacing the A/C belt on the pulley and causing the pulley to misalign and hit the power steering belt.
Here are some images of the gap between the pulleys:
Imgur
Imgur
Any help on fixing this problem will be greatly appreciated, thanks in advance!
Imgur
Imgur
I should also mention in the imgur photo where I highlight the gap space that the pulley is completely movable and I can pull it towards the alternator belt to make the alternator pulley and it complete flush.
I know that this pulley should not be free moving as it tends to move towards the engine block causing the power steering belt to grind against it.
There is a loud squeaking noise when the A/C is activated.
Randomly today the A/C was working briefly and it was still ultra cool.
But during the time of recording this video the A/C was only working about 25%.
If the A/C is off there is no squeak.
http://m.ebay.com/itm/221713597924?_trkparms=aid%253D222007%2526algo%253 DSIC.MBE%2526ao%253D1%2526asc%253D20150519202348%2 526meid%253Dfcb88a09dbf24d3a91c094d2e04fa343%2526p id%253D100408%2526rk%253D1%2526rkt%253D24%2526sd%2 53D221647654700&_trksid=p2056116.c100408.m2460
I've found that the part costs $220 and I'm defiantly sure that I cannot afford to buy this part.
I wonder if there is another alternative to a repair. I'm okay with no A/C because I'm used to that but it would be nice to know that the A/C works.
Meant to type $200 on that last post.
I was wondering if maybe it would be a good idea to bind together that broken pulley with the alternator pulley since that one isn't broken?
Not sure if it's a good idea but I would like to know some opinions on this.
Zonian22
11-14-2015 01:20 PM
Mike Bertram
09-10-2015 09:27 AM
asahrts
09-04-2015 05:55 PM
Zonian22
09-02-2015 08:19 AM
